Post by jsleeper on Mar 8, 2004 9:12:11 GMT -5
I just wanted to say thanks to everyone at the work weekend for their help and guidence for our first real offroad experience. We had a blast and can't wait for future trips to come.
Thanks, Justin and Jennifer
Stock Blue XJ
Post by toynrnd on Mar 8, 2004 12:39:28 GMT -5
I would like to say thanks to everyone who made it out to help with the trails this weekend. You all really worked your butts off and we got a lot accomplished even if it did sprinkle on us Sat. morning.
Justin and Jennifer, don't consider that Jeep stock anymore, it is "Trail Rated" now!
Post by bensredyj on Mar 8, 2004 13:32:18 GMT -5
Yea Chapel Trail rated from 12 easy to 1 difficult See ya next time. BEN
Post by Jesse Schneirla on Mar 8, 2004 14:36:45 GMT -5
Even Russ's Yota got stuck back on the chappel trail at the creek crossing, but so did Tim and Karen and everyone else n the group. I think Russ needs about two more gear combinations. Looking forward to a weekend that it doesn't rain! Chris you need to buy a crystal ball and pick a good date, or have Tommy use those sattelites to track the storms.
Jesse
Jesse
Post by A "CJ" on Mar 8, 2004 17:26:29 GMT -5
It was a great time! Getting stuck is cool, but I almost made it . Maybe next time... Oh and the big bad wolf blew our tents down too! Amazing what you can fix with duct tape, tie wraps and a couple of tent stakes ;D. til next time, Tim and Karen
Post by jpnut on Mar 9, 2004 8:20:32 GMT -5
Yea Chapel Trail rated from 12 easy to 1 difficult See ya next time. BEN hehehehe, it's a scenic trail honest. ;D You have plenty of time to get out of your vehicle to see the scenes.
Post by LILREDCJ6 on Mar 9, 2004 8:41:19 GMT -5
Is that the one that i made a really big mud hole in last time i was up there? Oh yeah sorry i couldn't make it this weekend. The Blue jeep wasn't ready and the brown one just isn't getting to the trails anymore. It doesn't need dents in it since it's going byby.
Post by jpnut on Mar 9, 2004 13:17:03 GMT -5
Yes that is the one. Apparently there is actually a stream before you get to the mud hole. And the bypass around the mud hole has a bypass now. I didn't see first hand.
Post by bensredyj on Mar 9, 2004 15:25:10 GMT -5
Yea thats the one, but now all the stream crossings will either need ROCK or a Bridge built, those little deceiving streams BEN
Post by stuck tj on Mar 9, 2004 22:31:23 GMT -5
Just ordered new lower control arm after running the new "scenic" trail. The Currie guy asked if I had run in some compitition they had out west this past weekend, I had to explane to him virginia has [glow=green,2,300]ROCKS[/glow].
Post by LILREDCJ6 on Mar 10, 2004 6:53:33 GMT -5
OK Mike how fast was you running the new scenic trail??? Which one did you bang up front or back?
Post by bensredyj on Mar 10, 2004 8:35:07 GMT -5
Hey Mike, are you gona send Currie the pictures? Maybe they'll give ya a discount BEN
Post by LILREDCJ6 on Mar 10, 2004 8:50:49 GMT -5
Yeah send on to Currie and send another one to Lyle so we can make fun of it. I am sure however you did it it was a spectaular show. Especially after what i saw you do at Uwharrie.
Post by Jesse Schneirla on Mar 10, 2004 11:57:50 GMT -5
Mike,
Weren't you the one that was high centered on your oil pan or was that someone else?
As for scenic...there are many photo ops of stuck vehicles! And good winching support. I think Tommy got to use his winch on that trail as did many others.
And yes, Tim you were close, but the cable was un-spooled from you winch also.
Jesse "Winch support guy"
Post by stuck tj on Mar 10, 2004 23:22:36 GMT -5
Ok first I was going slow, except for the sunden nitros boost. The truck was stuck on a pointed bolder between fron axle and the oilpan. Had to high lift to put rocks under the tires, at this point I had a tall rock in front of the rear driver side that i had to bump up and over. thats where I think things went really bad. slamed onto the control arm. Next we had to wench off the rocks , there was the roll factor. Then I hit the tree causing the limb to land on the hood, the crushed piaa light. ( do not buy the quattro set for off roading all plastic) and slight fender damage. I would like to thank all of the help to get me off the rocks. There needs to be a name for those rocks. Mine will not work. f1.pg.photos.yahoo.com/ph/lorenzian/album?.tok=ph036xABecbCqGjj&.dir=/cbe0&.src=ph
