Post by jeeepxj on Mar 19, 2009 10:38:10 GMT -5
SO here's s stupid question: The only stupid question is the un-asked question!
Post by ScramblerPat on Mar 19, 2009 10:45:30 GMT -5
No more lift I like the height as is. The primary goal is to put a three link on the jeep, the coil-overs are a result of that. (I will not require coil buckets and it opens up much needed space for links under the jeep) the desired outcome is better street characteristics, less brake drive, a suspension that does not take out the canister when it flexes and the side benefit is better front flex. The biggest reason to do it is for the fab experience, it will be fun. I am sticking to rear springs because it is done and a four link in the rear and 3link in front cost too much.
Post by 87B2XLT on Mar 19, 2009 13:45:09 GMT -5
I am guessing you got the 3-link kit like I saw on polyperformance.com. Yeah, getting the 3-link front and 4-link rear all in one shot IS a lot of money (around $2500 just for the kits, not including the coilovers...if I remember right) to spend at once when you may not have it available either in green mail or plastic. I can sympathize with that. Are you planning on eventually doing the 4-link in the rear? I'll be keeping up with this one so I have an idea of what may be involved, etc. if I undertake such a suspension modification.
Post by Deleted on Mar 19, 2009 14:26:29 GMT -5
If you are trying to keep up with Charles White, you are gonna need more motor. Did you get a good look at his CJ/YJ/F250? The custom Black Diamond is a work of art....
Post by jeeepxj on Mar 19, 2009 20:46:40 GMT -5
a suspension that does not take out the canister when it flexes and the side benefit is better front flex. Canister?? Does my suspension take out the canister when it flexes??
Post by ScramblerPat on Mar 19, 2009 21:11:07 GMT -5
With the present suspension and the arch of travel it has the tire will rip the charcoal canister out of the holder, no biggie I was just grasping at more reason to do the swap. ;D ;D
Post by 87B2XLT on Mar 20, 2009 3:01:58 GMT -5
Craig probably thought you were talking about the 'other' canister Good reason to mod the suspension, other than the extra flex if you ask me Dave G
Post by toynrnd on Mar 20, 2009 6:02:03 GMT -5
I say go for it. Everyone either continues modifying what they currently have or they keep on aquiring more projects. Either way, it is a sickness that seems to have no cure.
Post by ScramblerPat on May 7, 2009 19:32:09 GMT -5
Just to bring everyone up to date... I have been taking measurements, crunching numbers, taking measurements, reading ALOT and seeking advise.... I am almost ready to block it at start cutting. more pics to accompany the drawing later. thanks
Post by toynrnd on May 8, 2009 4:37:28 GMT -5
But have you taken any measurements? Good luck with this project!
Post by LILREDCJ6 on May 8, 2009 7:50:27 GMT -5
Just cut it up and get going on it. That way you dont have to drive the willy's at the Annual.
Post by bensredyj on May 8, 2009 8:48:22 GMT -5
Post by ScramblerPat on May 8, 2009 9:36:21 GMT -5
If I could just get my jeep to work off of green tape and 15 minutes of welding!!!! Nope not that good! I am dumb that way... And many other ways too.
Post by BIG J on Jun 23, 2009 7:38:22 GMT -5
getting anything done?
Post by bensredyj on Jun 23, 2009 8:45:46 GMT -5
I bet Pats pretty busy, just not with the jeep, keep up with the youngns this summer being the only parent. Have you taught Zack how to cut or weld yet? "Here, hold this"
