Post by toynrnd on Aug 22, 2010 19:09:32 GMT -5
Time to fab up something motorized to rotate the tubing while you weld. BTW, I wish I could see that much concrete in my garage.
Post by ScramblerPat on Aug 23, 2010 10:18:08 GMT -5
Post by toynrnd on Aug 23, 2010 10:40:13 GMT -5
The welds on the link ends came out nice. Are you happy with them?
Post by Deleted on Aug 23, 2010 11:06:39 GMT -5
Looks great Pat, I'm ooohhhing and ahhhhing over it. But what's the deal with the stacked washers on the knuckle end of the drag link? Don't want to pick it apart because I know you aren't done, but those washers will move around some, which will cause wear on the soft cast knuckle, which will cause them to move more; it's a cycle and will end up with the bolt hole reamed out. You'll tighten, it'll hog out and loosen, you'll tighten, it'll hog out more and loosen, etc....... It's already a very long bolt in single shear.
I think your welds look pretty good btw!
Post by bensredyj on Aug 23, 2010 12:36:16 GMT -5
Looks nice, Wonder how the new slenkys ride on an old buggy ride
Post by ScramblerPat on Aug 23, 2010 13:54:43 GMT -5
Keith thanks for your comments. I am using the washers to match the drag link to track bar angle. It will not be driven on. If you or anyone have ideas on how to create a steering spacer, let me hear it. I have a couple,,, but would like to see others ideas. I will not spend $800 to put high steer knuckles on a Dana 30, I will build something else first.
Chris, the fixture worked really well. however the monkey turning the bar was a little shaky.
Post by bensredyj on Aug 24, 2010 13:24:37 GMT -5
What about weldn the washers together or machine one cunk for a spacer, and weld that to the D-30? I have a couple spare TJ 30s if ya mess up.
Post by BIG J on Aug 24, 2010 13:43:35 GMT -5
i would be worried about welding on the knuckle, then having the all the stress of that single shear mount of the drag link; could snap off going down the road....other than that it looks nice
Post by ScramblerPat on Aug 24, 2010 15:39:54 GMT -5
i would be worried about welding on the knuckle, then having the all the stress of that single shear mount of the drag link; could snap off going down the road....other than that it looks nice So what would you suggest? How would you resolve the single shear on the draglink? And who is big J??? ;D ;D
Post by Deleted on Aug 24, 2010 19:57:10 GMT -5
Pat without spending a lot of money on an aftermarket knuckle there really isn't a good way to do anything different on that knuckle; it's probably going to have to be shingle shear. I agree that welding to the knuckle arm on a cast knuckle is a bad idea. I know why you want it shimmed to match the DL angle, but to me it would be best to compromise and not use extra spacers on that rod end. Just use the misalignment spacers that are on it so the bolt and distance are as short as possible and run it. But someone else may know something better than what I do.
Post by ScramblerPat on Aug 25, 2010 6:43:52 GMT -5
To clear up a couple things. If i was to weld on the outer knuckle it would be something like this. www.genright.com/ZoomImage.aspx?productID=STK2501 but there is still the metal composition concern. The shims that are seen in the picture are a measuring tool. if I insert a washer and measure the angle I then know I need 1.5" of elevation to match the track bar. The washers are ~1/4" each. The bolt is spare from the tool box not the bolt I plan on using. Once everything is measured and drivable the draglink will get put directly on the knuckle like keith mentioned and I will start the driving and enjoying.. If there is bumsteer the I can address that. if not than I can dance an Irish Jig that I saw on youtube One of my thoughts if bump steer is bad, is to get a block of 7000 series aluminum machined and drilled to fit over the knuckle piece and bolt to both the drag link and tie rod holes. the bottom of the aluminum would be counter sunk as it mates to the knuckle so there is support on three sides. I have a machinist buddy who works on base so that fix is cheap.
Post by ScramblerPat on Aug 25, 2010 6:46:34 GMT -5
What about weldn the washers together or machine one cunk for a spacer, and weld that to the D-30? I have a couple spare TJ 30s if ya mess up. Ben I could cut the draglink arrn portion off the outer knuckles you have and create this frankenstein thing that would make people scream and run when they saw it??? ;D even more than they will already!!!! ;D
Post by bensredyj on Aug 26, 2010 9:07:06 GMT -5
What about running a HIGH steer tierod, over the knuckle, and having the draglink connect to it kind of like the TJ, that might be 2" higher, someone had the drill bit to COUNTER the counter sunk knuckle.... OR lower the track bar mounting location.... OR redesign with 4 link to elimiate trac bar..... OR go back to leafs....
Post by bensredyj on Aug 26, 2010 9:33:42 GMT -5
www.bc4x4.com/pv/yj/histeer/www.4x4groupbuy.com/store/teraflex-dana-highsteer-system-tjljxjyjzj-p-4694.htmlTeraflex Dana 30 High-Steer System HSK, TJ/LJ/XJ/YJ/ZJ 4wheelonline.com/jeep/TeraFlex_Jeep_TJ_High_Steer_Systems.103401.304388TJ D30 High Steer Kit for 4+” lift - TERA-1813000 TeraFlex TJ D30 High Steer Kit for 4+” lift - Click to Enlarge INSTALL TIME: 3.3 hour avg. The TeraFlex high steer system was originally designed to be used with the MAX LCG, which utilizes a front 4-link triangulation (eliminating the trackbar). The High Steer Kit is essential in that application. Jeep®s with more than 5” of lift while still utilizing a trackbar system would benefit from a high steer solution. This kit will beef up the essential steering components of your Dana 30 front axle. The system includes a HD tie rod and drag link with one ton tie rod ends & tapered inserts, and the HD cast high steer knuckle. NOTE: The high steer system is not an all inclusive kit. Additional modifications will be required that are not included in the TeraFlex high steer system. These modifications may include front swaybar links, front trackbar mounting, and offset wheels. COMPONENT # DESCRIPTION QTY 4828490 high steer knuckle 1 4920244 HD drag link w/ends 1 4920251 HD tie rod w/ends 1 Price: $820.79 Sale Price: $615.59
Post by LILREDCJ6 on Aug 26, 2010 9:51:14 GMT -5
That knuckle is fine but, those tie rods tend to break. Trust me. Loved the steering part of it though.
