Post by IlovemyYJ on Aug 28, 2010 9:47:51 GMT -5
lol i hear yea...getting my engine swapped out..replacing it with the same engine..just a working one. my trans is a manual and i am hoping it works. i run 33s with 4:88 gears.
Post by 87B2XLT on Aug 28, 2010 12:09:45 GMT -5
Your transmission and tire size will determine your axle ratio. 4.88 for a standard transmission and if I read correctly a 4.56 for auto. That's to get back into a factory setup. Paul G. Paul, I have always seen lower factory gear ratios for autos, especially on tow package options. For instance, my '87 with no factory or dealer tow package and 5-speed manual has 3.45 gears. The '89 with automatic and (I'm assuming here, don't have original paperwork to verify) tow package has 3.73 gears. I've also seen bone stockers with no fluff where the slush-box equipped vehicles had the lower gears because of the inherent slippage and final transmission drive ratio differences - the 5-speeds generally run 0.79ish:1 and auto overdrives 0.75ish:1. Both of mine run roughly the same RPMs in overdrive @ 55mph - actually, the '89 runs at lower RPMs. I'm still wondering if there was a gear swap done on the '87 at one time or another, but the tags say it's got 3.45 gears. Sorry for the tangent.... Dave G
Post by gtmud on Sept 14, 2010 17:59:15 GMT -5
I am installing an engine for Matt, but I have found that the transmission input shaft has a lot of play up and down. I am thinking the main input shaft bearing might be the issue. Have yet to open it up to see the extent of the damage. any pointers.
Ken
Post by A "CJ" on Sept 14, 2010 19:49:37 GMT -5
Since the tranny made noise Might be the source of the problem.
What transmission is it?
Post by gtmud on Sept 14, 2010 20:05:36 GMT -5
Not sure, what would be identifiable castings?
Post by ScramblerPat on Sept 14, 2010 21:13:53 GMT -5
If there is too much play than there should be metal in the fluid.
Post by rroadkilll on Sept 14, 2010 21:23:28 GMT -5
I just found out that my donor motor for my jeep is bad!!! Back to the drawing boards...
Post by IlovemyYJ on Sept 14, 2010 21:44:42 GMT -5
did i hear what trans is it? its an ax5. i'm sure i just stated the obvious though.
Post by IlovemyYJ on Sept 26, 2010 22:57:41 GMT -5
its alive! thanks all and special thanks to Ken for the engine and trans work!
