Post by jeeepxj on Sept 30, 2010 5:52:01 GMT -5
Somebody make it stop.... Why?
Post by joshsbetterhalf on Sept 30, 2010 12:42:00 GMT -5
Oh god. My poor truck. Haha. Jk. I knew about all of this except the decision to bring it to annual.
Post by toynrnd on Sept 30, 2010 13:38:42 GMT -5
Here is some inspiration for your truck Candace... Black paint - check Lift kit - check Coilovers - check Bigger tires - check
Post by newt on Sept 30, 2010 16:43:26 GMT -5
35"s, at least one locker, loose the bed, and really good rockers/skids/bumpers/tow points - you should do fine at oakridge (if you drive smart - maybe Candice will drive).
The dude in the extracab dodge we took out this year did pretty well - his only real damage was passenger quarterpannel and tail light.
Post by joshbaker on Sept 30, 2010 16:57:42 GMT -5
yea gonna do a front aussie locker. Gotta see whats out their for the rear in a easy set up locker ie aussie or what not. Only gonna take the truck if i have made a flat bed for the rear. Also might do some nuts to the motor.
Post by joshbaker on Sept 30, 2010 16:59:29 GMT -5
Oh and yes it was the tow pig fer a while. Now its play toy.
Post by joshbaker on Sept 30, 2010 17:00:08 GMT -5
Somebody make it stop.... Why? yes big j do explain. I dont see this affecting you in any way?
Post by Jesse Schneirla on Sept 30, 2010 17:51:52 GMT -5
Josh, I guess since you could only move the pull sled a foot with the dually you have moved onto another project. Your almost changing projects as often as Fromme. For your next project I think you should remove the front tires put skies in their place, go to WV when it snows and give that a try. Might need some chains on those back tires? But if you've made up your mind, maybe we can sell tickets at the Annual to watch you bounce off trees. Didn't we have another Josh in the club with a black Dodge that did the same thing? ? Jesse
Post by BIG J on Sept 30, 2010 18:08:13 GMT -5
it just makes my head hurt that's all; I just can't keep up with you kids anymore.
Yea, Joshua Flinn tore up his 1500 Dodge at oak ridge
Post by newt on Sept 30, 2010 18:43:13 GMT -5
You don't need to build a flat bed - you just need to remove the stock bed (if it's not there you can't damage it) - after the weekend, you can put it back on if you want.
Post by toynrnd on Sept 30, 2010 18:51:13 GMT -5
You will do fine at Oak Ridge if: 1. You listen to your spotter, and 2. You ask for a spotter in those situations that appear questionable.
Many of the Oak Ridge trails were built using full size trucks as templates, so there is no reason you shouldn't be able to drive them now.
Post by Deleted on Sept 30, 2010 18:59:16 GMT -5
Bring on the trail cleaner!
Post by LILREDCJ6 on Sept 30, 2010 18:59:50 GMT -5
Does that mean after we make them wide enough to get a jeep through again?
Post by joshbaker on Jan 11, 2011 19:00:19 GMT -5
Ok so since this has become a thread about both trucks ill make it simple
Cummins truck: 1: Got 140hp over stock 7x.10 injectors installed 2: 3 piece exhaust mainfold on the way 2: intake horn on the way 3: 66/74/14 bullseye power turbo on the way 4: rear bumper being built 5: headache rack being built 6: front bumper done 7: 4k govenrer spring kit 8: AFC spring kit 9: head studs 10: 60lb valve springs
Black 4x4 1: 3" BDS lift kit 2: 34x10.50 SS LTBs 3: front tow points ( still working out the details) 4: at least a front locker
Looking into a new trailer for the black truck
Oh and just for those who cant add Once i put the new stuff on the cummins will be at right about 550hp and 900ft pbs of tourque at the wheels.
Post by bensredyj on Jan 13, 2011 10:20:51 GMT -5
So what will be the weak link on the diesel? Drive shaft or tranny? I think the 1500 should be a truggy.
