Post by Deleted on Sept 27, 2011 7:44:11 GMT -5
Nice! If the flexplate still give you issues we can arrange a work day for Meatbox maintenance.
Post by toynrnd on Sept 27, 2011 11:49:09 GMT -5
Put some JB weld on the edge of the flexplate, and turn the starter over so the fleplate makes 3 complete revolutions. Allow 24 hours for the JB weld to set and Viola! A new set of teeth for your rebuilt starter to engage.
Post by Deleted on Sept 27, 2011 13:13:16 GMT -5
Post by stumper92 on Sept 27, 2011 17:24:44 GMT -5
Is it going to make an appearance at my place on the 8th?
Post by Deleted on Sept 27, 2011 21:21:48 GMT -5
Is it going to make an appearance at my place on the 8th? That is the plan.
Post by Deleted on Nov 23, 2011 23:21:25 GMT -5
Picked up a couple of new treads today. I even bought a wheel stud and nut to replace the one I snapped off. Got a shinny fan clutch to replace the current screamer. Watch out, it may be seen on the road.
Post by stumper92 on Nov 24, 2011 6:35:03 GMT -5
You going to bring it by for a test run?
Post by Deleted on Nov 26, 2011 23:07:27 GMT -5
Latest great news.... I snapped off a wheel lug when I removed the tires. While attempting to repair that I broke a key washer in the hub. It is a dealer part and I put most of it back together. Then came the tire issue...I picked up a pair of tires from a co-worker's relative's tire store. He gave me a screaming deal, but did not adhere the wheel weights very well. They fell off when I put the first tire on the truck. Thinking I should push on, I changed the fan clutch without any problems. I wanted to hear my new quiet part work, so I attempted to fire up the truck. My old friend the flywheel is acting up again. It is grinding no matter where I rotate the crank. So I have a truck that won't run, a hub covered with a freezer bag, and two new Mud Rovers that have to go back to the lazy tire guy. It's a good thing I don't drink.
Post by stumper92 on Nov 27, 2011 6:33:13 GMT -5
Maybe not drinking is the problem... It would put things in perspective.
Post by Deleted on Nov 27, 2011 8:51:11 GMT -5
I am in the middle of removing expensive parts from the FJ, in a couple weeks I'll have a truly cheap FJ40 for sale. ;D
Post by Deleted on Nov 27, 2011 9:39:37 GMT -5
I am in the middle of removing expensive parts from the FJ, in a couple weeks I'll have a truly cheap FJ40 for sale. ;D I did see the wheels on Craig's. I am stuck with this and will have to see it through. At some point, all the worn and broken parts will be replaced. If it wasn't a blast to drive and a big beast, I'd push it out on Mount Pleasant. I think I have found out what I will do with 11 days off between Christmas and New Years.
Post by toynrnd on Nov 27, 2011 10:55:22 GMT -5
Will this be a work party or will you handle it yourself?
Post by Deleted on Nov 27, 2011 11:42:32 GMT -5
Will this be a work party or will you handle it yourself? I will need help for sure.
Post by stumper92 on Nov 27, 2011 15:23:15 GMT -5
I'm in...
Post by Deleted on Nov 27, 2011 17:12:47 GMT -5
Will this be a work party or will you handle it yourself? I will need help for sure. Let us know when and I'll do everything I can to help out.
