Post by stuck tj on Jun 7, 2013 6:50:07 GMT -5
OK so the 95 4 banger fuel injected is not starting. You have to turn it over usually twice for about 10 sec each time to get it to run. Runs fine at that point with no problem of restarting. New fuel pump, filter, regulator, cap, plugs, fuel cap, injectors are less than two years old. Guessing its loosing fuel pressure on the line to where its bleeding back to the tank? Any ideas.
Post by toynrnd on Jun 7, 2013 7:55:22 GMT -5
Do these tests please: 1. Turn the key on, how long before the fuel pump builds pressure and stops running the first time? 2. Turn the key on and let the pump run until it stops. Turn the key off. Turn the key on and let the pump run until it stops. Turn the key off. Keep repeating until the pump doesn't run when you turn on the key. How many times did you have to turn the key?
After test 2, would the Jeep start immediately?
Post by ex-tbd85hilux on Jun 7, 2013 11:17:39 GMT -5
Were the O-rings on the QD's replaced when the pump was changed? Had that issue with my 97 when I changed the pump a few years ago.
Post by stuck tj on Jun 16, 2013 7:14:47 GMT -5
The fuel pressure test, could not find a gauge. Had two but nothing to connect it to the the port, O rings no idea, I replaced fuel regulator and the pump relay, Same problem. Back at Starr
Post by Deleted on Jun 16, 2013 11:13:34 GMT -5
I can't help with this issue, but I love the pictures! Brings back some fond memories. My favorite is Debbie opening her door and having hundreds of pounds of rocks in tow.
Post by stuck tj on Jun 27, 2013 20:27:33 GMT -5
Ya as I had to drag her up the hill!
Post by stuck tj on Jul 31, 2013 5:53:21 GMT -5
Update, sounds like its the computer. Starr figures it out yesterday. Hope to have a replacement today as I plan to drive it up Friday.
Post by Jesse Schneirla on Aug 1, 2013 5:00:11 GMT -5
I was out there yesterday and they had your beep running good.
Post by stuck tj on Aug 1, 2013 21:05:40 GMT -5
Yes all is good in YJ land. Starr came through, Tommy figured it out! Runs like a top and also starts like a top? Got the winch reconnected along with a CB today. Ready to roll at a dark thirty tomorrow.
Post by CORE 4WD on Aug 6, 2013 18:57:15 GMT -5
I was gonna say push throttle until maximum speed is attained and then turn sharply left or right, preferably encountering an object such as a curb? But I guess you guys got it figured out....(see thread title for you slow guys haha!)
