Post by toynrnd on Sept 22, 2009 13:24:20 GMT -5
He should join the "G-Men"!
Post by Deleted on Sept 22, 2009 15:03:18 GMT -5
Do it, because it's the right thing tew dew.
Post by Deleted on Sept 23, 2009 2:59:25 GMT -5
Post by ex-tbd85hilux on Sept 23, 2009 4:28:51 GMT -5
Another Idea I've seen used at a lot of RV parks is a plywood cutout painted to the color that you want. 1 sheet of plywood a couple 2x4's and a jigsaw you should be able to cut and fit something that will stop this without having to buy a cover. Just an idea for you.
Post by toynrnd on Sept 23, 2009 4:38:45 GMT -5
Post by jeeepxj on Sept 23, 2009 5:15:19 GMT -5
You and your blue tarps!
Post by 87B2XLT on Sept 23, 2009 11:06:45 GMT -5
Sheesh. Tire covers that fit or spend the money on a building to put your trailer in.... Dave G
Post by ex-tbd85hilux on Sept 24, 2009 2:33:46 GMT -5
Sheesh. Tire covers that fit or spend the money on a building to put your trailer in.... Dave G Chris can't do this... Every time he builds another building he has to get more Jeeps for the Museum. ;D Paul G.
Post by jeeepxj on Sept 24, 2009 5:46:29 GMT -5
Post by BroknCJ on Jan 22, 2010 23:02:46 GMT -5
Another thing to check is the valve stems. Got back from last deployment (okay so it was 13 months and all) Long story short, checked the tires, looked fine, hooked up the trailer to go pick the CJ up from VA...didn't get 30 miles before shredding both right side tires...the valve stems had split by the rim...tires went flat...then shredded the tread...prob would have noticed earlier if it hadn't been empty trailer and 5:00 in the morning when I started out. Other than having to buy two new tires and loosing some time no biggie...but a bummer because of a couple of bucks worth of valve stems.
Post by jeeepxj on Jan 23, 2010 0:23:46 GMT -5
Wow, there's a blast from the past! Welcome back Ken!
Post by BroknCJ on Jan 23, 2010 10:03:04 GMT -5
thanks Craig. Tho still down in Georgia for a while longer.
