Post by KarlVP on Jan 25, 2005 19:58:35 GMT -5
How do you get a stripped lug nut off? I can't get mine off. It's stripped on the outside. Not the inside.
Post by 350pwrdcj7 on Jan 25, 2005 20:08:09 GMT -5
take a socket that doesn't quite fit on the nut and beat it on with a big hammer and it will lock on good enough to take off the lug nut, you do the same for wheel locks if you don't have the key.
Post by IEATMUD on Jan 25, 2005 20:10:32 GMT -5
Craftsman has a tool for stripped nuts and bolts it is a socket that self adjusts to the required dimensions of the nut or bolt.
Post by ex-tbd85hilux on Jan 29, 2005 8:46:37 GMT -5
I got the easy outs for nuts for christmas. If you still need them give me a call I'm on watch today till 1530 (330pm) anytime after that should be good.
Post by ex-tbd85hilux on Jan 29, 2005 8:47:13 GMT -5
my number is 581-3831
Post by KarlVP on Jan 30, 2005 21:12:24 GMT -5
I got them off. I used the socket technique. It worked rather well. Thanks for your help guys.
Post by HarvinJeep on May 7, 2005 8:31:01 GMT -5
weld a nut to the side of it and get out the breaker bar. Works on the locking ones if you either break or lose the key.
