Hard Starting Cherokee? Oct 25, 2005 11:21:37 GMT -5 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by Lyle on Oct 25, 2005 11:21:37 GMT -5 Does your older XJ or MJ crank for several seconds before starting? For one potential solution, click below:Use a BMW fuel line check valve to eliminate long cranking times!
Hard Starting Cherokee? Nov 14, 2005 8:41:31 GMT -5 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by smrflng on Nov 14, 2005 8:41:31 GMT -5 I will have to give that a try. My 89 takes longer to start than my 90. Thanks for the info Russ.
