EricT
Short Timer!
Post by EricT on Feb 3, 2003 8:07:16 GMT -5
So, I am slowly getting the jeep ready for the trek out west. I installed 6* shims under the rear axle to get my pinion pointed more at the t-case than the front axle on saturday morning. Sunday after finishing my brothers exhaust on his vw, I pulled the jeep back in the garage to lift the front 3/4" and ream out my UCA axle bushings to 7/16" since the 3/8" bolts moved a little more than I liked. Also to rotate the front axle pinion a little skyward. I had forgotten what a PITA it is to remove those coils and ended up taking most of the suspension apart. I saw a few places that I should have clearanced before I finally got it all back together too. Oh well, maybe next time, if I do that again
EricT
Short Timer!
Post by EricT on Feb 3, 2003 8:15:54 GMT -5
I forgot to add: All I have left to do is: Install my 1" lift shackles in the rear get my front bumper winch basket fabbed (tomorrow) get paid and order the RE drop brackets and lube/rebuild driveshafts I think that is it
Post by Lyle on Feb 3, 2003 18:44:24 GMT -5
I forgot to add: get my front bumper winch basket fabbed (tomorrow) Hi Eric, Curious... what does that mean? What are you having made?
Post by jpnut on Feb 3, 2003 21:31:17 GMT -5
Hi Eric, Curious... what does that mean? What are you having made? I think I have seen the design. Eric is really getting ready for his trip across the country. His new bumper design resembles a cow catcher that you would see on an old steam train. It kills the approach angle but it sure can plow some ground.
EricT
Short Timer!
Post by EricT on Feb 4, 2003 8:38:00 GMT -5
That's funny, I'll have to remember to have that option built in
EricT
Short Timer!
Post by EricT on Feb 4, 2003 8:52:50 GMT -5
Post by jpnut on Feb 4, 2003 8:53:15 GMT -5
Well I could have used that option last night on the way home from work. Counted 24 deer, 1 cat and 1 rabbit and didn't hit a one of them but it wasn't so good for the brakes with the panic stops. Came around one corner to find 9 deer in the road. And they say not to make sudden and sharp turns in a Wrangler.
Post by jpnut on Feb 4, 2003 9:05:33 GMT -5
actually it is more like what Paul has on his MJ. A cross between these two. Well it should keep critters out of the radiator.
Post by Lyle on Feb 4, 2003 9:32:45 GMT -5
Eric, That looks pretty trick - I imagine it would take a good hit! You're having someone locally weld it up for you to your specs? Edit: Just a side note... you've probably already thought of it, but you might want something on there to mount your front license plate.
EricT
Short Timer!
Post by EricT on Feb 4, 2003 10:02:43 GMT -5
Eric, That looks pretty trick - I imagine it would take a good hit! You're having someone locally weld it up for you to your specs? Edit: Just a side note... you've probably already thought of it, but you might want something on there to mount your front license plate. A buddy of mine is doing a favor for me to weld it up. I'll have a TIG, stick and plasma cutter at my disposal. Along with some milling machines and lathe. ;D I should have brought my camera with me to take some pictures. Also, as for the plate, that is what zip ties are for
Post by bensredyj on Feb 4, 2003 10:13:42 GMT -5
just bring extras zippys for the trail or cut them so you don't loose your plate Thats cool When will it be completed?
EricT
Short Timer!
Post by EricT on Feb 4, 2003 10:39:55 GMT -5
hopefully we will have the basket for the winch done today. The round tubing can wait till after this weekend, unless Sonny has some more time this week and I can get a hold of Pauls tubing bender.
EricT
Short Timer!
Post by EricT on Feb 4, 2003 21:24:57 GMT -5
basket is done, i'll take some pictures tomorrow. tubing will be bent and added next week
EricT
Short Timer!
Post by EricT on Feb 6, 2003 0:44:28 GMT -5
EricT
Short Timer!
Post by EricT on Feb 10, 2003 7:39:21 GMT -5
more pictures are up
