Post by smrflng on Mar 24, 2005 8:54:47 GMT -5
Invest in a rope ladder or a large step stool and all will be well. ;D ;D ;D
Post by IlovemyYJ on Apr 22, 2005 7:21:23 GMT -5
wow that thing is gonna be really nice
Post by BroknCJ on Jun 27, 2005 19:25:20 GMT -5
Post by PaulC on Jun 27, 2005 21:32:06 GMT -5
How much is that box going to go into the radiator support, grill, and fender. Maybe you could take a section out of the shock hoop and move the front verticle bar back the needed length. Which way does the box rotate the sector shaft?
Post by BroknCJ on Jun 27, 2005 21:55:07 GMT -5
actually it turns the opposite way it needs to with the 4x4 internals. I need to swap in the 4x2 worm gear and rack so it will turn opposite. I have a box off a 79 4x2 already that I got just to use the parts out of it. Just by eyeballing it I don't see any reason it wouldn't work once I put the smaller pitman and 4x2 worm and rack in it. If I keep the box in that cutout in the frame it should clear all the grill/fender/rad etc...If it doesn't....Guess I'll have to do some more fabrication to make it work
Post by BIG J on Jul 16, 2005 9:28:49 GMT -5
Hey Ken, is this still Melissa's ride ? It is...but she's been giving me an earfull since she realized how tall it's gonna be on 35's ;D when you get to the annual check out what Donny did for Trish so she could get in the buggy.
Post by BroknCJ on Jul 18, 2005 14:32:38 GMT -5
Well the Bronco is going on hold for a few months and I wont be able to make the annual trail ride (with or without the bronco) gotta do some job stuff over there for a few months...Catch up with you guys when I get back. Hopefully I'll be able to jump on the forum occassionally while I'm gone and maybe post a few pics from where I'm going. -Ken
Post by BIG J on Jul 18, 2005 20:39:23 GMT -5
um, didn't you move so that work would be close to home?
Post by BroknCJ on Jul 18, 2005 20:50:26 GMT -5
Not unless the Navy starts a war in Maryland
Post by IEATMUD on Jul 19, 2005 7:10:50 GMT -5
lets invade Canada. EH?
Post by JeepinGoose on Jul 19, 2005 11:03:05 GMT -5
ya lets invade canada
with thier flapping heads and beady eyes.
Blame Canada!
Post by BroknCJ on Apr 23, 2006 19:45:41 GMT -5
Update on the Bronco. Got some work down on it since I've gotten back home. Got the steering box mounted as well as the hi-steer tie-rod drag link setup I got from complete off-road. (also have the reamer for the GM 1-ton tie rod ends if anyone local needs it) Turned out pretty sweet except I need to move my bottom track bar bolt up about an inch. Will help it clear the flipped steering and help with the angle to keep the bump steer to a minimum. Just need to find a new bolt somewhere for it, so far I can't find one quite big enough to do the job. As soon as I find an acceptable one I'll finish the bracket and whatnot. was hoping to have gotten a little farther along but had some poblems with some vendors sending me wrong parts. It happens and they were all great about getting the correct brackets out to me, but it held me up a bit. Got the new bearings pressed on the rear axle shafts today, just need to get 10 new CJ wheel studs, press em in with the new brake rotors and bolt the new brakes and brackets on, run the lines and the new disc brake setup will be pretty close to being all done. Got a new pully setup off a 90 bronco at the junk yard for the motor and got that all on the motor with a new water pump as well as a new set of headers. only thing left on the motor should be the radiator and installing the wiring harness. Holding up on starting the harness and installing the dash, until I get the rear back together and tow it up to get the inside of the tub shot with Line-X. Also got the floor shifter (with brackets cable etc) fabbed and mounted temp cause it will come back out also to get the tub shot before I finish mounting it permanent like. Anyway coming along slowly. Was going to post some pics but the digi camera went back to best buy today cause it's jacked up, so I wont have it or a replacement for a week or two. (glad i got the stupid warranty for once) Will post some when I get a chance to. -Ken
Post by smrflng on Apr 25, 2006 9:02:29 GMT -5
Nice to see that you are getting a chance to get some stuff done. Are you gonna make it to the annual this year?
Russ
Post by BroknCJ on Apr 25, 2006 15:16:00 GMT -5
Russ I hope so. Got a real bug to get the bronco up and mobile again. Hoping it might actually make it out to a trail or two sometime this summer.
Post by PaulC on Apr 25, 2006 21:47:41 GMT -5
Ken,
Hopefully you weld the nerfs bars on better then you did the Rubi. J/K.
