Post by RuffRider on Jan 9, 2006 17:40:57 GMT -5
Ordered the super duty 231 sye and drive shaft from Tom Woods, Daystar rear uppers, and yellow top Optima from Quadratec.. Everything is supposed to be here by Thursday, which is when the air compressor should arrive..... fingas crossed...
Post by Jim63 on Jan 9, 2006 18:04:04 GMT -5
sweet maybe ill get to see the sye install this weekend when i get home from school. I dont have to work till sat at 4 so ill be able to help out...dave when are you thinkin about doing this
Post by RuffRider on Jan 9, 2006 18:08:10 GMT -5
I think Dave is going out of town this weekend, prolly be a next week thing..
Post by CORE 4WD on Jan 9, 2006 20:22:52 GMT -5
I go out of town (darn the real job) on business Sunday. I'll get it done the week of the 21st unless you get the parts to me Friday a.m. Doesn't really matter, still got a half day of little stuff to do anyway before driving. Here's your e-brake adapters- Nut trial fit after boring out to fit cable end- Rough mock- This nub keeps bracket located on arm- Done- Breather bolt is next...
Post by RuffRider on Jan 9, 2006 20:27:18 GMT -5
Sweet Dave, b/c I have to get inspected b4 end of month. And I'm sure e-brake is needed to pass.. Reminds me, I need a new windshield, also.
Post by CORE 4WD on Jan 9, 2006 21:14:28 GMT -5
Don't sweat the inspection. While the inspection station I use does an absolute by the book job I can take it for pre-inspection and get the "iffy" things looked at and qualified (or not). Your windshield should be fine, no spider web and one straight line crack on p-side. I'll run you through the things you need to make it easier...
Post by RuffRider on Jan 9, 2006 22:41:25 GMT -5
Whew.. I always sweat the lil' stuff...
Post by CORE 4WD on Jan 10, 2006 16:14:01 GMT -5
Breather bolt completed- Bolt cut to length- Rough pieces, used a section of 1/4" rod and drilled out for vent then pressed into bolt- Bolt drilled- Installed-
Post by Jim63 on Jan 10, 2006 16:46:26 GMT -5
lookin good!!! Wish i wasnt back at school
Post by RuffRider on Jan 10, 2006 20:27:10 GMT -5
WoooHoooooo!!! ;D ;D ;D ;D Thanx, Dave... And the adj. rear uppers are here.......
Post by CORE 4WD on Jan 10, 2006 21:03:22 GMT -5
Bring them over ASAP...
Post by RuffRider on Jan 10, 2006 21:57:41 GMT -5
The man wastes no time....
Post by CORE 4WD on Jan 10, 2006 22:32:05 GMT -5
Git'r dun! ;D
Post by RuffRider on Jan 11, 2006 0:52:04 GMT -5
Core and To The Floor
Post by CORE 4WD on Jan 11, 2006 17:30:31 GMT -5
You know it! Glad I picked up arms, they weren't painted. Now they are- Got t-case out and fabbed up the work stand I've been meaning to make, needs paint-
