Post by Chele on Jul 9, 2007 4:23:34 GMT -5
Looks good! You're making excellent progress....one thing at a time and before you know it, it will be done!!
Post by CORE 4WD on Jul 9, 2007 7:02:48 GMT -5
New rear axle install pics at top...
18July07...pics added
Post by broncobilly on Dec 2, 2007 19:08:17 GMT -5
Let's see the progress. I know you have been fiddling with her so post up.
Post by CORE 4WD on Dec 3, 2007 20:51:50 GMT -5
Lol fiddling is just about right! I DID re-locate the fuel fill port to accommodate the stretch. Now the hose goes up through the taillight area, comes out about a foot behind the normal spot. Hooked up the e-brake. Dang holidays are killing my wallet AND my time! I am determined to get back on a normal garage schedule, get that D60 in and get to work on some "other" stuff, not mine. I'll get pics up when I get back in town. Dave Part of the stretch is re-locating the gas fill port, now it's behind the tail light- my.photodump.com/davephillips/fill tube_R-672-T.jpg[/IMG][/URL] my.photodump.com/davephillips/fill tube_R-457-T.jpg[/IMG][/URL] my.photodump.com/davephillips/gas fill relocate-T.jpg[/IMG][/URL] Anti-wrap bar- my.photodump.com/davephillips/traction axle-T.jpg[/IMG][/URL] my.photodump.com/davephillips/traction shackle_R-324-T.jpg[/IMG][/URL] Flares- my1.photodump.com/Anonymous/side front-T.jpg[/IMG][/URL] Ok, pics "preview" fine but won't actually post. What gives?? I already tried losing the URL and a number of different combos thereof...
Post by CORE 4WD on Dec 21, 2007 13:28:33 GMT -5
Update-21December
Ok, the extended arms are just about done. Fender flares are on after opening up fenders. Now it's looking more like a Bronco should. Then wedge spacers need to be made and calipers need to be ground a little to fit the new wheels. Spin Bronco around and pull front out. I'm trying to post pics...
Post by 87B2XLT on Dec 21, 2007 16:10:28 GMT -5
Dave, you probably need to change the image posts in the other post(s) to use the tagged info in the "Post" block for the image page(s). Seems like Photodump is a little different than other sites on that. Lookin' good on progress, and an FYI I am free mostly until Christmas Day. Kinda spaced on calling you last time like I had mentioned, but will try again this weekend. Dave G
Post by greenbean on Dec 21, 2007 20:18:19 GMT -5
Dave, I hope the New year will find you finishing up the EB brother, it is going to Rock! Merry Christmas Brother!!! Awesome work on everything you do man!!!
Post by CORE 4WD on Dec 22, 2007 0:37:24 GMT -5
Me likey photobucket. Flares are on- Gas fill relocated, need to route fill and vent hoses up more to body, fenderwells still need stretched- New tube route- Here's the anti-wrap bar I made a while back and couldn't get the pics to load- Thanks for the spring perch Norm. Makes a good axle bracket!- Protects the driveshaft a bit, PaulC I'm going to try and get this driveshaft back to you BEFORE it gets twisted! It IS a J**p shaft afterall. I do thank you though - That's an XJ shackle up there. Allows for front to back movement of axle. May have to rod end it, won't know until I cut out inner fender wells and ramp it- Extended arms are almost done. Nothing fancy. We'll see how long 3/4" rod ends hold up to dropping onto rocks. Could probably drill and thread up to 1" rod ends if they break often. They are easy to change out on the trail at least. Any inputs?- Everything is 1/4". These were cut using Harbor Freight plasma cutter, the $500 one. Cut right through, made it very easy. Ok, so I'm a little shaky-
Post by PaulC on Dec 22, 2007 10:16:59 GMT -5
Nothing but red X's man.
Post by 87B2XLT on Dec 22, 2007 15:45:43 GMT -5
Hmmm. Looks like the image codes aren't posting right, or they're not public? Weird. I tried viewing the images individually, and photobucket promptly gave me the finger.... " There is no content in this album."
Post by CORE 4WD on Dec 26, 2007 21:45:11 GMT -5
Need to plate the flat top and bottom part , weld it all up. Then finish-grind the arms.
Post by onewyr on Dec 26, 2007 21:52:43 GMT -5
Post by CORE 4WD on Dec 26, 2007 22:03:31 GMT -5
Yea they've been around for the EB's for years, built by B.C. Broncos. Not needed when running extended arms plus they're a fair amount of work...check out BroncoBilly's flex shots in his build up. His junk works great on the trail. Needs 10 pack leaves in the back for a little better ride and balance out the suspension movement as compared to the front.
Post by CORE 4WD on Dec 29, 2007 19:47:32 GMT -5
Welds on one arm are ground out- Need to make c wedge spacers and grind calipers to fit wheels next
Post by onewyr on Dec 29, 2007 20:39:03 GMT -5
man those are some sexy arms I need to make a set of extended arms for my truck
