Post by What It Was on Dec 30, 2007 13:39:56 GMT -5
I read somewhere that those arms would be stronger and get a better movement if they had a slight bend... I can't really put it in words, I'll have to draw it up and post... Some of the Monster trucks are running something similar.... You're not worried about coming down on them, "pinching" and then having them fold between a hard spot and a rock
Post by CORE 4WD on Dec 30, 2007 14:31:25 GMT -5
I read somewhere that those arms would be stronger and get a better movement if they had a slight bend... I can't really put it in words, I'll have to draw it up and post... Some of the Monster trucks are running something similar.... You're not worried about coming down on them, "pinching" and then having them fold between a hard spot and a rock The mainstream company's ie; Duff's, Tom's Bronco Parts, CAGE etc put a bend in them for turning radius. Also, when you retain the stock width axle and put on a longer arm, this leaves the attaching point inboard of the frame rail. I'm going full width so I can put the axle wedges where ever needed as well as frame attaching points. It may end up limiting my turning radius a bit but will hopefully save the d60 axle u-joints by not over-turning them. Anybody ever pop a D60 u-joint in a hard turn? I've seen it a couple times... Midyette Machine said they will rethread the arms for 1" rod ends if I end up having a problem with the 3/4". Rich, I bet you have access to a big press if I needed to put a bend in them, aayy? ;D
Post by What It Was on Dec 30, 2007 16:57:58 GMT -5
Who me? ;D
Dane
New Member
Post by Dane on Jan 2, 2008 20:11:50 GMT -5
Dave, have you heard from the machine shop yet about the other arm?
Let me know if you'd like some assistance when you get it.
Post by CORE 4WD on Jan 3, 2008 22:13:50 GMT -5
Alex did a "field trip" with me to the machine shop. Arm is done and awaiting final weld and grind...tomorrow afternoon after throwing some gear into the heep. Drop by after work if ya want!
Dave
Post by 87B2XLT on Jan 3, 2008 22:30:58 GMT -5
I may call and drop by tomorrow as well... got some stuff I need to work on doing at the house, though. Things are looking good and like they're coming together fairly well!
Post by CORE 4WD on Feb 22, 2008 23:14:06 GMT -5
I've got one bolt to drill out and tap on a radius arm then I can put the front D60 in. Thanks Dan (Dane) for helping out with fitting the new wheels ei; grinding out the calipers to fit them! That was fun-on off on off on off!
Dane
New Member
Post by Dane on Feb 23, 2008 6:44:45 GMT -5
Not a problem Dave. Let me know when you need more help. We've got to get your Bronco on the trails! I'll be on lv the 1st wk in March so maybe we can get some stuff done. ;D
Post by CORE 4WD on Feb 23, 2008 23:34:32 GMT -5
Hey PaulC thanks for dropping off the 203/205 stuff. I'll get with you about the adapter kit...
Post by CORE 4WD on Mar 1, 2008 21:31:12 GMT -5
D44 is out, D60 is ready to go in. Need to cut off stock frame mounts and fab new mounts. Dave, need to know where to drop off D44 and do you need stock radius arms?
Dave
ogea
Post by ogea on Mar 1, 2008 23:12:01 GMT -5
Dave, Looked real good today when I stopped by man. I was really impressed!!! Can't wait to see it out on the trails.
Adam
Post by CORE 4WD on Mar 2, 2008 9:30:59 GMT -5
Thanks Dane for all the help! We'll get back on it Monday if you want to.
Adam, your Jeep is looking good. I think those tires/rims look perfect on there! We're going to have to hit up Harold's sometime again! Harold? You out there? Ready to make some new trails? heh heh
Dave
Post by onewyr on Mar 2, 2008 15:51:01 GMT -5
sounds like it is coming along great dave I can't wait to see it on the trails by the way which event do you think will be it's maiden voyage
Post by CORE 4WD on Mar 3, 2008 22:22:38 GMT -5
Hey Dave, where ya want your axle? ;D- Dan helping drop the D44- D60 ready to go in-
Post by RuffRider on Mar 4, 2008 23:54:32 GMT -5
I wanna turn some wrenches 2. it's been a while.
