Post by toynrnd on Jul 24, 2006 22:03:09 GMT -5
While Noah was sleeping Saturday, Seth and I decided to fix his alignment problem in his Jeep. The plastic starts to wear out with all those miles on the trail, so the Jeep had a severe "alignment" problem. Even though it was really hot out, we broke out some tools... ...worked up a sweat... ...and got the job done. We tightened up all the press on lock washers, cut the flat bar tie rod, spread it about 1/4", and bolted on a reinforcing bar with a perfect alignment. Once Noah got up, a test drive was in order. The Jeep handles like a...well, like a Powerwheels Jeep now. One Jeep ready for Camp Jeep, one to go.
Post by smrflng on Jul 25, 2006 7:17:05 GMT -5
I guess that is all you can work on in the garage since I see its still not cleaned out. ;D ;D ;D ;D
Post by toynrnd on Jul 25, 2006 7:23:33 GMT -5
The CJ7 fits in there w/ room to spare. It was in the yard for trailer moving duties.
Post by A "CJ" on Jul 25, 2006 16:56:45 GMT -5
The CJ7 fits in there w/ room to spare. It was in the yard for trailer moving duties. Jeep, the original John Deere tractor..... tim
Post by LILREDCJ6 on Aug 1, 2006 21:06:54 GMT -5
I'm liking the looks of the blue grill in the back ground. You could make some more room in that garage if that was out of the way. I am sure Ryan would like one.
Post by Deleted on Aug 1, 2006 23:10:45 GMT -5
Hey Boucher, I was thinking about putting some flotation wagon type tires on ours. There's no traction with those plastic things. Think the gears would hold up, or would it instantly strip them?
Post by toynrnd on Aug 2, 2006 5:20:51 GMT -5
I wondered about using those wheels too. They would ride better. But what do you air down to if you start out at 10 psi??
Post by CORE 4WD on Aug 2, 2006 7:17:30 GMT -5
That's a common mod, make sure you have extra couplers to swap out cuz yea they get better traction! Makes it a little harder to steer also, especially if aired down but hey it's good arm excercise for the little guys...
Post by smrflng on Aug 2, 2006 9:47:46 GMT -5
You should get some really spongy tires and air them up to about 20 psi. that way Noah could bounce all over the yard.
Russ ;D ;D ;D ;D
Post by bensredyj on Aug 2, 2006 10:20:18 GMT -5
Need some beach tires, i have my riding lawn mower tires AIRED down for a nicer ride on the bumpy yard, INNER TUBES baby.
Post by 87B2XLT on Aug 2, 2006 23:10:57 GMT -5
I'm wondering if someone could machine up some metal replacement parts... like the gears, etc. That would make for some interesting results ;D
Post by my95yj on Aug 3, 2006 1:18:58 GMT -5
what's that a bayliner i see in there? looks like a late 80's color scheme!
Post by CORE 4WD on Aug 4, 2006 7:49:24 GMT -5
I'm wondering if someone could machine up some metal replacement parts... like the gears, etc. That would make for some interesting results ;D Yea I'd like to see a 4wd model. Maybe strip one of those little Kubota 4WDs and stick a body on it? Too bad they want so much coin for those Li'l Mudbuster EB bodys...
Post by toynrnd on Aug 15, 2006 16:14:34 GMT -5
what's that a bayliner i see in there? looks like a late 80's color scheme! 1985 Sunbird w/ 115 hp outboard. Currently used as a tool support shelf for Jeep projects.
Post by LILREDCJ6 on Aug 15, 2006 16:47:55 GMT -5
chris do ya want to get rid of that old jeep in the back ground? If not which ones are you parting with. Ryan wants something to tear apart and put back together.
