Post by joshbaker on Jan 29, 2009 22:04:28 GMT -5
hey i am wondering if anybody knows if this will help with bump steer or not and if it is cost efective? cost about $200. thanks
Post by toynrnd on Jan 29, 2009 22:17:57 GMT -5
Bump steer? Do you have extended shackles in the front, or are they stock length?
Post by joshbaker on Jan 29, 2009 22:18:55 GMT -5
stock length
Post by toynrnd on Jan 29, 2009 22:30:10 GMT -5
Have you had your caster angle checked?
Post by joshbaker on Jan 29, 2009 22:31:48 GMT -5
not yet thats next on the list
Post by bensredyj on Jan 30, 2009 9:10:11 GMT -5
YJs don't need the trac bars, only for inspection. How much lift do you have? did you have to extend the trac bar mounting points? Specs on your rig please? Save the $$$ on trac bars.
Post by LILREDCJ6 on Jan 30, 2009 9:25:03 GMT -5
Make all the brackets disappear and then there is no need for trac bars. YJ's came with them but, as Ben said they are not needed. If you have bump steer Josh it may be caused by the lift you put on the jeep. Do the springs have degree shims attached where the spring meets the axle? If so they may have thrown your caster off.
Post by Deleted on Jan 30, 2009 9:37:50 GMT -5
If he added a drop pitman arm that will cause bump steer if the angles between the tie rod and track bar are different. Like Tony said, take it off and don't look back. You'll probably get more articulation too.
Post by bensredyj on Jan 30, 2009 10:47:50 GMT -5
I thought only one set of lift springs would have shims and they would be for the REAR, do fronts have shims as well?
YJs like to have their draglink paralle to their tierod if possible, hows your look?
Post by joshbaker on Jan 30, 2009 12:26:41 GMT -5
it has a drop pitman arm and the drag link is almost leval. the shackles are forward alot and jackie says that is because the spings have flatened out alot and the springs are really soft. not shure what the lift is but its a 3 1/2 inch with degree shims on the back
Post by bensredyj on Jan 30, 2009 14:26:36 GMT -5
Could the shocks be bad or the steering stabalizer? , hence when you hit a bump, your bouncin all over the place? any info on this lift? 3 1/2 lift should not flatten out too much??? Could the stock shackles be TOO short to limit travel of the springs? Some run a 1/2 to 5/8 longer shackles with lift springs.
And you checked the torque specs of the shackle bolts, NOT OVER TIGHTENED? chance you can post some pics?
It could be the road itself, is it a rough section or ........
Post by joshbaker on Feb 3, 2009 12:47:03 GMT -5
well the spings are really soft and so i am gonna get a new lift and new sterring stableizer cuz mine is leeking and see what happens from their. jack says thet the spings are really soft to soft and the shocks are worn out also because of the spings being to soft so thanks for the help i am not going to wast money on the trac bar
Post by bensredyj on Feb 3, 2009 15:13:35 GMT -5
Any idea whch manufactuter's spring are on the jeep? number of leafs? 4,5,6,...
Post by joshbaker on Feb 6, 2009 17:46:43 GMT -5
not shure of the brand but they have 5 in the front and 4 in the back with i believe or should say what look like bilsteen shocks but not for shure oh and the spprings are military wrap spings
