Post by Deleted on Mar 23, 2010 12:35:20 GMT -5
Ijust cant do everything at once. None of us can, but you confuse us when you talk about doing 8 different things all in a weeks time.
Post by joshbaker on Mar 23, 2010 13:35:03 GMT -5
So what yer sayin is my brain is to fast fer yall. lol just kidding. This is the tenative plan, I am getting the gen right rear 6" fender flares and building the rear tire holder. Putting the fluids in it and a tom woods d/s. Then gonna drive it till i gotta redo something.
Post by 87B2XLT on Mar 23, 2010 14:17:20 GMT -5
So what yer sayin is my brain is to fast fer yall. ADHD, what? Just messin' Josh. I can relate to having 'all this stuff' you want to do, but I've come to terms with waiting until something breaks or doing a build as time permits. There are, however, some things I really want to get done before I 'wheel my junk after I get home Dave G
Post by joshbaker on Mar 24, 2010 18:05:21 GMT -5
Yea a little bit of ADHD and anxiety. The anxiety is why i gots to get booted out of the navy.
Back to my heep. I am very happy person today cuz ups has my d/s and ill get it next tuesday. Then i can weld the rear axle and put some break lines on it and drive her home.
Post by joshbaker on Mar 28, 2010 16:30:41 GMT -5
So craig got me a set of tj flares. just another thing to add to the to do list next weekend. thanks craig
Post by joshbaker on Mar 30, 2010 20:31:24 GMT -5
Got my d/s today. I do believe that is the last part i was waiting on. Gonna weld the spring perches and shock tabs saturday and then drive it all weekend. Just gonna drive to drive
Post by 87B2XLT on Apr 2, 2010 17:41:20 GMT -5
I just might get to drive all three of mine this weekend, too. Er, I meant all three that are in TX, that is Dave G
Post by joshbaker on Apr 2, 2010 18:52:21 GMT -5
Cool man. I must have spoke too soon because i just found out i wont be driving mine till monday or tuesday
Post by 87B2XLT on Apr 2, 2010 20:53:40 GMT -5
d'OH. That sucks.
Post by joshbaker on Apr 3, 2010 20:10:46 GMT -5
Yea but it gave me a chance to go to pnp and have some fun. tomorrow im gonna set the pinion angle and put the brake lines on the 8.8 and mark the spring perches and shock tabs for jackie to weld monday
Post by joshbaker on Apr 4, 2010 16:08:11 GMT -5
So i filled the t case, tranny and the rear diff. Also did the oil change. Routed the brake lines for the back. Tomorrow ill set the pinion angle and mark it so jack and i can weld it. Then blead the brakes and she's on the road again.
Post by joshbaker on Apr 5, 2010 20:18:54 GMT -5
So thank you jack for welding the rear axle for me.
Got the axle welded and bolted back in. Finally done with that. Went to bleed the brakes and found out that i cant get the front bleeder screws to open. So i went and got new calipers. Also got new brake pads. That should fix the problem.
Post by joshbaker on Apr 6, 2010 21:01:15 GMT -5
So i got the spring perches and shock tabs welded finally and bolted the axle in for the last time. Got the rear brakes bleed as good as i can untill the fronts are done. So here is why i hate the dang jeep. I went to bleed the front brakes and cant get the dam bleeder screws to open. So i went down to auto zone and got the calipers. And now i just dont have the drive to work on it. This "2 weekend max" project has become a never ending money pit and pita. So I need some encouragement. I just dont think it will ever be finished. This seems to be harder than a frame swap which only took me a month
Post by Deleted on Apr 6, 2010 21:05:54 GMT -5
Use some large vice grips and muscle to crack those bleeders open. Then you can take those calipers back and get your money back, and they should have new bleeder screws you can replace with. Or you can do like I did on the Bronco, and just keep using vice grips on the rounded off bleeders. They don't have to be cranked down tight. Worse case scenerio you break the bleeder screws off, then in which case you can use the new calipers. But I'd sure as hell work on them until they either cracked loose or broke off, you've got nothing to lose. If you aren't strong enough, eat a bacon sandwich or find someone that is.
Post by toynrnd on Apr 6, 2010 21:31:21 GMT -5
So I need some encouragement. GO JOSH! GO JOSH! GO JOSH! How about a cheer? RAH RAH REE...KICK 'EM IN THE KNEE! RAH RAH RASS...KICK 'EM IN THE...... OTHER KNEE! lol
