Post by joshbaker on May 1, 2009 12:26:48 GMT -5
well i sanded the surface rust and used some etch primer and will also use black primer with zinc in it. also i am going to redo all the welds on the frame tomorrow and then cut the mounts off for the track bars since i don't need them or use them and it will be less to explain to an inspector since their wont be any mounts missing things attached to them
Post by joshbaker on May 5, 2009 17:26:22 GMT -5
ok the body is off and the new frame ready to go. I am also going with greaseable shackles and main bolts all around with a 1inch lift
Post by joshbaker on May 5, 2009 18:44:35 GMT -5
well make it 1 1/14 because it was the same price. The shackles are from warrior products and the main eye bushings are from day star. maby ill be able to put it all back togather some day and drive it again lol
Post by onewyr on May 24, 2009 21:08:00 GMT -5
between yesterday and today we got the axles,motor/tranny/tcase and the tub installed on the new frame I guess all he has left is putting the front clip back together and getting his wires and vacum stuff hooked back up
Post by stuck tj on May 25, 2009 9:37:18 GMT -5
Nice. Has he sold the old tires and rims?
Post by onewyr on May 25, 2009 21:26:38 GMT -5
yeah the guy came and picked them up from my house and he pretty much just handed the money over to me
Post by joshbaker on May 29, 2009 20:18:28 GMT -5
yep that was what happened. i got to keep $25 because i also had to buy a set of longer brake lines for it to. Going to take it to ociana tomorrow and finish it . then drive it.
Post by joshbaker on Sept 15, 2009 20:52:30 GMT -5
ok so me and bryan are going to start the next stage on the yj. I am going to put the 8.8 from a 95 explorer in it. i am leaving the limited slip in it but upgrading the gears to 4.88. will let you all know how its goes as wee get it done.
josh
Post by joshbaker on Sept 22, 2009 20:25:35 GMT -5
ok bought the m.o.r.e. install kit orderd this weekeknd and also going to put a three inch body lift on it and 35inch ss ltb. i think i have the same tire issue as fromme lol.
Post by LILREDCJ6 on Sept 22, 2009 20:41:27 GMT -5
You shouldn't since Bryan drove them everywhere. Not to mention if you are having the same problem why would you got get the same tire in a larger size?
Post by Deleted on Sept 22, 2009 21:24:14 GMT -5
Don't do a 3" body lift. Get out the sawzall and trim the fender openings, and get some TJ flares.
Post by stuck tj on Sept 23, 2009 6:57:42 GMT -5
Yes no 3 " body lift!! Beg borrow or steel parts for a lift (like Andy) but do not do a body lift.
Post by bensredyj on Sept 23, 2009 10:33:04 GMT -5
You could get away with a 1" body lift, and 1 " motor mount lift but NOT a 3". Then some TJ flares and see where your at. what springs and shackles ya runnin? WOW an 8.8, let me know how it goes, I have one in my garage from a few years back I thought about swapn. got 4.10s and discs, just need the motivation good luck. Ben
Post by 87B2XLT on Sept 23, 2009 11:00:13 GMT -5
Isn't a 3" body lift 'illegal' in Virginia anyhow I don't think I'd go over 2" for a body lift - I'd probably opt for a 1" body and motor/trans mount lift and sheetmetal manipulation. Dave G
Post by toynrnd on Sept 23, 2009 11:13:13 GMT -5
A 3" body lift is legal in VA. That's the maximum.
