Post by Deleted on Jul 16, 2009 15:51:58 GMT -5
I knew someone here would pretend to like me enough to stay past 3.
Post by joshbaker on Jul 16, 2009 18:51:04 GMT -5
hey you know ill be the last one out. see you their fromme
Post by stuck tj on Jul 16, 2009 21:37:22 GMT -5
Josh is my subordinate at the STARR STATION, so I am ordering him to stay and keep everyone company till the last person is gone. ;D
Post by greenbean on Jul 19, 2009 13:49:15 GMT -5
Adam, I signed in with the wife's account on snapfish and was able to view 2 pics?!? Was that all you posted? If so, it works!
Post by Deleted on Jul 19, 2009 14:15:02 GMT -5
Adam, try using photobucket. Then you can post the pictures directly in the thread.
Post by newt on Aug 8, 2009 13:58:41 GMT -5
What the sign / bikini top looks like with a little Starr Motors mud thrown in just for fun. Adam
Post by onewyr on Aug 8, 2009 20:25:49 GMT -5
Hey adam call JR enterprises in chesapeake for your steel you can get it by the foot 543 2066
Post by newt on Sept 7, 2009 16:40:46 GMT -5
Tony,
Since you gave me so much crap, I've mounted the winch - I'll see you at the annual to finish wiring it and the optest. ;D
Adam
Post by newt on Sept 25, 2009 16:34:59 GMT -5
Post by newt on Oct 21, 2009 6:01:58 GMT -5
I've got two projects I want to attack next on the Heep.
First I want to lower it some by re-working the leaf spring mounts. This is simple on the fixed end - just drill holes in the mounts ~ 2" higher, but it will be tricky on the shackle end especially for the front axle. I want to fab a longer shackle that mounts the top end through the center of the frame - drill hole, sleeve, re-enforce etc, but I don't have the fab skills. In the rear I need to make sure the traction bar geometry isn't dorked up by moving things. Anyone want to volunteer to help me out with this?
Once I've got that completed, I'm figuring out hydro steering assist ....
Adam
Post by jeeepxj on Oct 21, 2009 6:43:43 GMT -5
I've got two projects I want to attack next on the Heep. First I want to lower it some by re-working the leaf spring mounts. This is simple on the fixed end - just drill holes in the mounts ~ 2" higher, but it will be tricky on the shackle end especially for the front axle. I want to fab a longer shackle that mounts the top end through the center of the frame - drill hole, sleeve, re-enforce etc, but I don't have the fab skills. In the rear I need to make sure the traction bar geometry isn't dorked up by moving things. Anyone want to volunteer to help me out with this? Once I've got that completed, I'm figuring out hydro steering assist .... Adam Sounds like a perfect new project for you and Keith and his new welder. Well.... if you can talk him into buying Brian's welder
Post by newt on Nov 3, 2010 19:48:47 GMT -5
An update: This last weekend at Starr I managed to break the main leaf of the front right leaf spring pack, bend the tie rod some more, and increase the leak at the left rear wheel cylinder and at the steering gear box pitman arm seal.
I hope to have the Heep repaired enough for the Harlan trip next weekend. Craig has some leaf springs, I'll fix the brake leak, carry extra steering fluid and hope for the best, but I don't know what to do w/ the tie rod. How can I get it straight and how can I get it sleeved?
Post by CORE 4WD on Nov 4, 2010 7:33:56 GMT -5
An update: This last weekend at Starr I managed to break the main leaf of the front right leaf spring pack, bend the tie rod some more, and increase the leak at the left rear wheel cylinder and at the steering gear box pitman arm seal. I hope to have the Heep repaired enough for the Harlan trip next weekend. Craig has some leaf springs, I'll fix the brake leak, carry extra steering fluid and hope for the best, but I don't know what to do w/ the tie rod. How can I get it straight and how can I get it sleeved? Hi Adam! Hit up Tim at Shakerbilt in Chesapeake. I can't imagine a piece of DOM threaded for your tie rod ends would be too much at all. Either that or just hook a winch to it and straighten it out. Or pull it off and prop it on a block and drive onto it or or ;D
