Post by Deleted on May 27, 2009 11:46:47 GMT -5
We have a regretful modification list, what are the ones you're glad you did and would do over again? Or the mods you're glad you didn't do.
suspension seats lots of armor C02 tank and I'm glad I didn't do any engine or exhaust mods.
Post by JeepCJ5 on May 27, 2009 12:34:46 GMT -5
I'll reduce this down to most used mods. Would have the be: Detroit locker in the rear and on board air.
Post by greenbean on May 27, 2009 13:30:31 GMT -5
Long arms Cheap $50 Pep boys air compressor Armor (Need corners still - Rokmen Hoplite!!!!!) Locker Bypass ORO Swayloc
Post by Deleted on May 27, 2009 13:32:14 GMT -5
Good call on the Swayloc. One of those or a Currie Antirock is a must.
Post by LILREDCJ6 on May 27, 2009 16:55:15 GMT -5
None I hate my piece,
Post by newt on May 27, 2009 18:11:32 GMT -5
Skipping straight from stock axles to Dana 60/14bolt w/ Detroits on my CJ.
The twin stick on my Dana 20 w/ Dana 18 parts and no interlock pill - makes for a smooth positive shift and I can do front only Lo or Hi, rear only Lo or Hi, 4wd Lo or Hi (and also the undesirable front Hi/rear Lo or vice versa ...).
Good rock rails, corners and fenders so that dents take some real effort.
Good seats.
Just about everything else I've done I think I could have done better (hindsight being 20-20).
Adam
Post by smrflng on May 27, 2009 19:17:49 GMT -5
Lockers front and rear, But then I realized power steering was a must. 173 to 1 low range isn't bad either.
Russ ;D ;D ;D ;D
Post by jeeepxj on May 27, 2009 21:01:34 GMT -5
None I hate my piece, Tony I hate your piece as well !! ;D
Post by ex-tbd85hilux on May 28, 2009 1:34:02 GMT -5
Lockers front and rear Dual cases Transfer case Ebrake means I can actually stop on the trail without resting the body on a tree! Budbuilt crossmember/skid plate keeps the drivetrain nice and high and gets rid of the cumbersome hang up point of the factory stamped crossmember.
Post by BIG J on May 28, 2009 9:17:31 GMT -5
on board air, and the winch. doesn't matter if you're lifted or not, you can still be self sufficient. oh yea, and welding the front diff None I hate my piece, Tony that's cause it has a WV tag
Post by LILREDCJ6 on May 28, 2009 10:33:54 GMT -5
None I hate my piece, Tony that's cause it has a WV tag[/quote] Not for to much longer.
Post by toynrnd on May 28, 2009 10:47:45 GMT -5
Winch...first thing on every vehicle. No matter what other mods you do, you always end up needing a Plan B eventually.
On the CJ7, I like the NP 435 and Tera Low 4:1. Can you ever be geared too low?
Post by Deleted on May 28, 2009 10:53:01 GMT -5
None I hate my piece, Tony that's cause it has a WV tag Not for to much longer. [/quote] Oh reary? Do tell.
Post by A "CJ" on May 29, 2009 11:58:11 GMT -5
First and best I built a Jeep CJ gears and lockers swampers warn full floater warn conversion hubs front CV rear drive shaft t-18a w/6.32:1 1st , thanks Chris B on the find fiberglass body w/full cage tied to frame 8274-50 winch
to make it better, rear disc brakes, caddy calipers with btf brackets coming this fall/winter
Donny
Post by Donny on Jul 7, 2009 9:04:46 GMT -5
On my TJ:
Winch (Wedding present from my wife!) 4.5" Rubicon Express lift (Wish they had come out with the long arm kit at first) Dana 44 Rear Bestop Trail cover WJ Front Calipers Replacing stock y bar steering with separate drag link and tie rod as part of the caliper swap JB Conversions Super Shorty kit on the T-Case (3 1/2" Shorter than the original SYE kit!) Coming Soon AW4 auto tranny!
AW4 auto is working great!
