Post by joshbaker on Jun 11, 2011 16:18:43 GMT -5
Ok so I sold the yj a long time ago and while I don't miss it I want something to OffRoad in. So picked up an 89 v6 regular cab short bed Dakota. It's already 4x4 and has a 5speed. Plan is to do a 2" body lift and 31's. Wheel it till I get all the stuff necessary to do a 12 bolt rear and waggy 44 front. It's not in great shape. Pass side door banged in pretty bad but ah who cares it's just gonna be a wheeling rig. I'll have pics up as soon as I get the Internet working again at the house.
Post by joshbaker on Jun 12, 2011 14:05:34 GMT -5
found a set of 88 waggy d44's. And it beggins..................................
Post by ex-tbd85hilux on Jun 12, 2011 19:23:48 GMT -5
I'm thinking a 4bt and some 35's!
Post by jpeay on Jun 12, 2011 20:34:58 GMT -5
just got my hands on a 4bt from a scrapyard out of a wrecked frito lay truck only 86700 miles on thinking dropping in my cj instead of a 360. Need to find a th400. I dont the front axle will hold the weight though
Post by joshbaker on Jun 24, 2011 7:16:58 GMT -5
Going to go d44's front and rear. 2" lift wagoneer springs in front and bastard leaf packs and a possible shackle flip in rear. 5.13 gears and full time lockers front and rear. 2" body lift. Winch in front. That's about it.
Post by joshbaker on Jun 28, 2011 7:09:49 GMT -5
Post by joshbaker on Jul 3, 2011 22:01:07 GMT -5
Well found a place that actually says their sue will work with the 231d t case. Anybody have a sand blaster I can use? Need to blast the backing plates for the rear axle.
Post by joshbaker on Jul 14, 2011 14:34:36 GMT -5
Ordering the gears, install kits f/r and a spool for the rear tomorrow. Got a 3.92 and up carrier for the front delivered today. Going to get a lunch box locker for the front soonly.
Post by travito on Jul 27, 2011 10:19:15 GMT -5
I look forward to working on this one man...
Post by joshbaker on Aug 8, 2011 12:01:02 GMT -5
Haha yea I'm sure you do. I just wish I had more money to buy stuff for it. But the axles are almost ready for y'all. I think im going to go ahead and get chromo shafts for the rear on my next order. As far as progress. I have everything for the diff's, inner chromo shafts for the front. The t case is out. Next stuff I'm ordering is chromo outers bearings and seals for front and rear, sye, 760 u joints. Then I should be getting the outer knuckles and lockout hubs and some other misc stuff from Travis early next month. Then it's time to save all the money I can so Travis can build my dream truck. Well at least get it driving on the d44's. Btw Travis I appreciate the help. And info.
Josh
Post by CORE 4WD on Aug 18, 2011 19:45:10 GMT -5
Well found a place that actually says their sue will work with the 231d t case. Anybody have a sand blaster I can use? Need to blast the backing plates for the rear axle. This may be a little late, but I use a generic blaster that you stick in a bag of (dry) playsand. A little messing (use headgear, goggles, earplugs to keep sand out) but it's like $13 at Northern. Sand at Home Depot a couple bux. You can borrow it if you like but I'm at Beachfront so considering gas you're prolly better off just buying one out your way! That will be a light weight rig! Should be fun once you get the better axles in. ;D
Post by joshbaker on Aug 19, 2011 23:56:39 GMT -5
Got the front gears setup a couple days ago. Started working on the rear tonight.
Post by joshbaker on Sept 4, 2011 21:37:19 GMT -5
Diff's are setup. Need to get some stuff for the front still but should be ready by mid month. Rear need axle bearings and seals. Ordered them Friday. Also ordered the sye Friday.
Post by joshbaker on Sept 18, 2011 18:56:37 GMT -5
Rear is pretty much done. Just need brakes. Waiting for parts for the front.
Post by toynrnd on Sept 18, 2011 20:14:35 GMT -5
Pictures??
