Post by Marshall on Jul 11, 2011 13:24:40 GMT -5
Whoops.... I thought it was a good idea to drive sideways on a rock
Post by Deleted on Jul 11, 2011 14:40:48 GMT -5
Well in defense of the driver, he was doing exactly what the spotter said to do. That had to be the worst line the spotter could have had the driver take.
Post by newt on Jul 11, 2011 19:41:50 GMT -5
If you search Youtube for MOAB ROCKER KNOCKER you'll see that that is actually pretty close to the preferred line for the smaller tired guys. Most folks sort of crab across it diagonally until they get the wedge then bump the rear up. It's very high pucker factor for sure.
Some coil spring suspensions (especially w/ sway bars disconnected) really unload quickly.
Post by ScramblerPat on Jul 12, 2011 23:05:27 GMT -5
At $32,000 to $45,000 for a rubicon unlimited me thinks I will retire from any and all spotting. Especially for the next 2 years!
Post by Deleted on Jul 13, 2011 8:01:27 GMT -5
If you search Youtube for MOAB ROCKER KNOCKER you'll see that that is actually pretty close to the preferred line for the smaller tired guys. Most folks sort of crab across it diagonally until they get the wedge then bump the rear up. It's very high pucker factor for sure. Some coil spring suspensions (especially w/ sway bars disconnected) really unload quickly. You're right, that is a good line....just not for that vehicle.
Post by smrflng on Jul 13, 2011 8:18:05 GMT -5
But then again the vehicle that went in front of that rubicon was probably a toyota and had no problems. silly Jeep drivers.
Russ
Post by Deleted on Jul 13, 2011 10:58:54 GMT -5
What they didnt show was the toyota flipping the jeep back over and then pulling it over that obstacle.
Post by ScramblerPat on Jul 13, 2011 15:30:21 GMT -5
If you search Youtube for MOAB ROCKER KNOCKER you'll see that that is actually pretty close to the preferred line for the smaller tired guys. Most folks sort of crab across it diagonally until they get the wedge then bump the rear up. It's very high pucker factor for sure. Some coil spring suspensions (especially w/ sway bars disconnected) really unload quickly. You're right, that is a good line....just not for that vehicle. What are you saying that one line does not fit all??? I think if the wheelbase was just 8" shorter all would have been fine Who is ready for Camp Jeep and all the Rubicons?
Post by Deleted on Jul 13, 2011 16:38:46 GMT -5
I thought C.J. was kaput. It's back? I can't go, unless they allow a Chevota to participate. Or guide. ;D
