Post by Deleted on Mar 8, 2012 12:24:00 GMT -5
Also, if you're not going to contribute anything worthwhile then
timbillyosu
A bad day fishing is still better than a good day working.
Post by timbillyosu on Mar 9, 2012 10:47:37 GMT -5
Anyone have any recommendations for auxiliary lighting? The bumper I ordered has 4 light tabs. Think it would like kind of silly if I don't put something in those spots
Post by ScramblerPat on Mar 9, 2012 16:33:48 GMT -5
The warn HID lights. Easy to instal nice light and small. A little expensive
timbillyosu
Post by timbillyosu on Mar 21, 2012 10:12:28 GMT -5
Anyone run a bikini top that they really like and is fairly easy to install? And I'm talking the Jeep kind
timbillyosu
Post by timbillyosu on Apr 27, 2012 7:47:56 GMT -5
Thinking a lift is in my future :-) Leaning towards the Teraflex SKU: 1352002: www.teraflex.biz/jk-2-5-lift-kit.html#firstFrom some of the stuff I've read, the stock Rubi shocks with adapters would still work pretty well but I'll probably just replace them later anyway. Has anyone had any experience with this or a similar kit? Any other suggestions? I've heard a lot of really good things about Old Man Emu, too. With that kit, will there be anything else I need to pick up besides wheel spacers? Any spacers that can be recommended also? My plan was going to be to get a set of 33s and the lift when my current tires wear out. Then I go to thinking, hmmmmm, I could lift now and get the tires when I need them :-P
Post by Marshall on Apr 27, 2012 11:21:30 GMT -5
Myself and Paul G. Run this lift....I am more than satisfied with the teraflex product and performance!! Aside from the main kit, I also added an adjustable track bar and lower control arms. I have since replaced my front drive shaft due to the factory boot tearing under flex. If your looking to just run 33's you can use their leveling kit and save quite a bit of money, and it still looks good!! If you have any questions or want a closer look at the lift feel free to give me a call.
OME also makes a nice kit for the JK as well a Rock Crawler! Good luck!
timbillyosu
Post by timbillyosu on Apr 27, 2012 11:44:20 GMT -5
Well, I'd also like to add a bit more ground clearance, not just tire clearance.
timbillyosu
Post by timbillyosu on Apr 27, 2012 11:46:21 GMT -5
Also, the 1.5" Performance Leveling Kit is only $100 cheaper and doesn't include anything for shock length, brake lines, or rear track bar.
