Post by smrflng on Jul 8, 2012 14:40:37 GMT -5
Paul,
That's a wait and see thing. I am going to get it installed and work the bugs out of it first.
Russ ;D ;D
Post by toynrnd on Jul 8, 2012 15:01:11 GMT -5
F comes before T in the alphabet.
Russ, the proper order:
diesel flapper turbo
Post by smrflng on Jul 16, 2012 8:47:37 GMT -5
Well finally got the truck around front, and more parts removed. Russ ;D ;D Attachments:
Post by toynrnd on Jul 23, 2012 6:09:43 GMT -5
Keep going Russ! Do you know what size the exhaust will be so you can get the right size flapper? When you're done, someone will be waiting...
Post by smrflng on Jul 23, 2012 10:37:43 GMT -5
Not exactly sure on exhaust size yet. But I have got the exhaust pipe off the manifold to go by.
Got the new engine ready for the adapter. I suppose all I have to do now is order it. Didn't get as much done this weekend due to the crappy weather. But that probably won't happen until after I get back from Maine.
Post by cbrogers on Jul 23, 2012 10:45:55 GMT -5
There was a guy at the Pa. Jeeps show that does the whole Mercedes Swap Kit. Looked pretty straight forward, and supposedly there is most all of the info on the swap on his site. I can get that info if you wanted. I think that he was out of Md. He had a CJ there that had been converted already.
Carl
Post by smrflng on Jul 24, 2012 6:30:07 GMT -5
I have heard of that guy in MD. They do mostly jeep stuff. Only guy that I have heard of that make an adapter for toyota transmissions.
Russ ;D ;D
Post by cbrogers on Jul 24, 2012 16:31:27 GMT -5
Well Pa was a Jeep Show, but I thought that I saw he had an adapter that will work on the Toyota transmission. Basically 2 parts, the bell housing to Engine plate, and then a machined spacer for the crank to flex plate / clutch plate.
He had stuff to adapt exhaust and such also. Kind of a one stop shop, but you can buy al-a-cart the parts as you need them. Real nice guy and willing to talk.
You might check out his site if you get stuck or need a little help.
Carl
Post by smrflng on Aug 16, 2012 14:20:24 GMT -5
Well progress has been slow, but thats ok since I did go to Maine for a week. I have managed to get the remote oil filter adapter finished. Its not the prettiest but it does fit and all the holes line up. Russ ;D ;D Attachments:
Post by Jesse Schneirla on Aug 16, 2012 14:59:27 GMT -5
Looks like prime work done at Norfolk Naval.
Post by smrflng on Aug 16, 2012 15:33:08 GMT -5
Not done there, still finding aluminum shavings all around the garage.
Russ ;D ;D
Post by smrflng on Sept 21, 2012 12:33:55 GMT -5
Haven't got much done lately but did get a new bumper mocked up for the front. Still have to wire up the lights and fill in a couple of holes. Russ ;D ;D Attachments:
Post by PaulC on Sept 23, 2012 21:35:10 GMT -5
Russ,
Didn't know making a bumper was part of an engine swap. JK. Looks good. When are you going to see black smoke coming out of your Toy.
Post by smrflng on Sept 23, 2012 21:52:19 GMT -5
Actually I didn't build the bumper, I got it off craigslist. Not really sure when the black smoke will happen. fixing a few problems with the frame. Still have to pull the yota motor out. But at least its in the garage.
Russ ;D ;D
Post by BIG J on Sept 24, 2012 6:07:40 GMT -5
you're getting rid of those weld on tie down right......
