Post by whoistylerdurden on Dec 27, 2012 22:45:44 GMT -5
This what I am starting with Attachments:
Post by whoistylerdurden on Dec 27, 2012 22:46:37 GMT -5
The other side Attachments:
Post by Deleted on Dec 28, 2012 12:44:51 GMT -5
If you don't want to do a frame swap and you're sure the rest of the frame is good, then I guess it looks like you could drop the tank, drop the rear spring hangers, remove the body bolts and lift the tub up, and use a slug inside the frame, and replace the rotten part. Not a fun job and tight working quarters but you can do it! That's what I intended to do on my very first CJ, but after consulting with many people, and receiving help from many people, I did a frame swap. Which then snowballed in to a 5.0/NP435/D300 swap.
Post by onzrocks on Dec 28, 2012 15:12:53 GMT -5
I know someone with a complete CJ7 frame for sale, no rust, and completely boxed in. PM me if you are interested and I can put you in touch with him.
Post by PaulC on Dec 28, 2012 19:16:37 GMT -5
Post by whoistylerdurden on Dec 29, 2012 7:04:26 GMT -5
I decided to cut out the rusted stuff made the replacement parts. I will post pics soon. Thank you for the links on jeep4x4center, that is exactly what I made.
Post by whoistylerdurden on Dec 29, 2012 7:52:52 GMT -5
driver outer Attachments:
Post by whoistylerdurden on Dec 29, 2012 7:54:26 GMT -5
passenger outer Attachments:
Post by whoistylerdurden on Dec 29, 2012 7:55:15 GMT -5
passenger inner Attachments:
Post by whoistylerdurden on Dec 29, 2012 7:57:15 GMT -5
drivers inner Attachments:
Post by whoistylerdurden on Dec 29, 2012 7:58:38 GMT -5
passenger side new piece, well almost. Attachments:
Post by whoistylerdurden on Dec 30, 2012 19:50:54 GMT -5
Got most of the welding done, but still need to do the bottom. This is the passenger side. Attachments:
Post by whoistylerdurden on Dec 30, 2012 19:54:18 GMT -5
Driver side. The more I work on this jeep the more I realize that a boxed frame with no drain holes on a off road vehicle is not the best idea. Attachments:
Post by toynrnd on Dec 30, 2012 20:35:05 GMT -5
Looking good!
Post by whoistylerdurden on Dec 31, 2012 19:35:57 GMT -5
All done, just need to install the tank and bumper
