Post by PingPong on May 8, 2015 10:13:09 GMT -5
Located IN middlesex VA 23070
Will ship on your dime
Np435 Chevy Bell housing Novak 23 spline conversion 450
203/300 doubler 2000
Dodge 203 drilled and tapped for 6 bolt round
Also have a chevy 203 range box and a chevy 350/203 mount
Jeds Machine doubler
Flipped 300 using Down East off road flip kit
4-1 gears
32 spline outputs front and rear
1350 CV yokes
Atlas shifters
ALso have 3 push pull cables to make shifters out of.
Warn 8k winch with remote 450
Ramsey 8k Winch no remote 250
stock d300 with unistalled 32 spline out puts and 1310 yokes 500
98 4.3 complete from TB to base pan no asseciories 300
4 14" FOA Coilovers with remote resivoirs and dual rate kits.
GM D60 4.10 gears Artec truss, artec LCA mounts, and Barnes upper mounts set up for triangluted front. Artec style Hi steer arms with Arp studs 1700
Dodge rear artec truss, Artec Mounts Rotors and caliper stand.. axle is still assembled but all the parts above need to be welded on 600
39.5 Pitbull Mad dogs groved and slightly worn mounted on H2 rims with 2 rims machined to fit on the rear 900
Full Hydro Steer setup PSC 8" DE ram, P pump, orbital mount Danfoos orbital, hoses mounts and clevises. Basically everything but cooler and res . Orbital and pump used. all other parts NEW in packaging 1000
10 Gallon aluminum fuel cell and custom mount. this is the square style tank. The mount has BIO hazard symbol and Radiation symbol cut into brackets. 200
4 core aluminum radiator with dual electric fans 150
4 core Chevy truck radiator 50
jeep 2.5 raditor with electric fan 75
2 2.5" flow master 40 series mufflers used 50
2 PRP Tweed seats. no rips, but been sitting in the garage a few yrs. 1 is a wide width the other is regular width 400
Scout d300 missing bull gear, 100
Zuki tin top body.. qtrs cut, floor board cut. no glass or back door. will include 2 sets of fenders and 1 set of doors and 1 hood. plus a stretched frame 200
2 empty 9" axle housings big bearing ends 25 each
80 chevy truck d44 center section... gears are still there.. 25
d44 8 lug outers and inner c's with shafts and calipers. 150
Artec triagulated rear four link brackets welded together
Will work a package deal on the zuki, axles, 1 winch, links and brackets, 4cyl radiator, tires, coil overs, 4.3/435/300 4000
PM your number and I will text pictures.
No trades
Paypal accepted if you pay fees
Shipping on your dime. Will ship everything but will expect you to arrange shipping on the larger items. will ship and package anything but you will have to pay for shipping supplies and I will provide the receipt.
__________________
chop top xj 3
4-1 gears
1350 CV yokes
Atlas shifters
No trades
__________________
chop top xj 3
