Post by Lyle on Jun 14, 2004 11:28:14 GMT -5
Post by bensredyj on Jun 14, 2004 12:38:32 GMT -5
Should have paid more attention to the WARNING label on that bottle. BEN
Post by toynrnd on Jun 14, 2004 12:45:17 GMT -5
Another Camp Jeep guide slot mysteriously becomes available...
Post by Lyle on Jun 14, 2004 13:00:01 GMT -5
"I thought YOU called Miss Utility!"
Post by Lyle on Jun 14, 2004 13:03:11 GMT -5
"The last I saw Big J, he had just taken a big swig outta that bottle. When I turned back around, he was gone, and there was this big burned spot on the ground. I thought I heard him yell 'CONGRATULATIONS'."
Post by toynrnd on Jun 14, 2004 13:08:41 GMT -5
Vicky gets revenge for the rock rash on the XJ.
R.I.P. Danny
Post by Lyle on Jun 14, 2004 15:30:41 GMT -5
From Big Mike:
And you say that was a billion power spotlight?
Post by stuck tj on Jun 14, 2004 17:01:21 GMT -5
Mike showing the finer points of road repair.
Post by Deleted on Jun 14, 2004 18:09:03 GMT -5
Another end to a fine night of broadcasting on the Blue Ridge Cable Access Channel.
Post by YJ Ken on Jun 14, 2004 21:18:48 GMT -5
"Do you think this obstacle will be to tough for the Libertys?"
Post by KarlVP on Jun 14, 2004 21:36:54 GMT -5
"Do you think this obstacle will be to tough for the Libertys?" I laughed so hard, I almost crapped my pants.
Post by jpnut on Jun 15, 2004 7:50:04 GMT -5
Now Bill, you aren't paying attention. You have to slowly sweep your shovel across the dirt spreading it in an even pattern.
Post by PaulC on Jun 15, 2004 9:29:09 GMT -5
VDOT's finest at work.
Post by BIG J on Jun 15, 2004 19:02:43 GMT -5
This operation is clearly against VDOT regulations, shovels are to be used for leaning not shoveling; if you need to shovel something then you call in a backhoe.
Post by jpnut on Jun 16, 2004 8:21:33 GMT -5
This operation is clearly against VDOT regulations, shovels are to be used for leaning not shoveling; if you need to shovel something then you call in a backhoe. I bet Mike gets written up then for not following the VDOT guidelines.
