Post by CORE 4WD on Feb 17, 2009 18:49:15 GMT -5
So where does everyone go to get their trailer inspected? Anyone use a facility in/near V.B.?
Thanks for any info...
Dave
Post by toynrnd on Feb 17, 2009 19:07:01 GMT -5
Park Auto in South Norfolk.
Post by FJ40Fran on Feb 17, 2009 19:42:35 GMT -5
So where does everyone go to get their trailer inspected? Anyone use a facility in/near V.B.? Thanks for any info... Dave Thomas Trailer at 3215 S. Military Highway.
Post by Deleted on Feb 17, 2009 19:45:58 GMT -5
I use a shop in Suffolk if you want to drive that far.
Post by Deleted on Feb 17, 2009 20:25:05 GMT -5
There is a shop at the end of Dean Drive that can do trailers. The inspector has property near the Dry River District, as him about it.....
Post by 87B2XLT on Feb 18, 2009 6:12:27 GMT -5
Kind on-and-off-thread here - I asked while I was on leave about inspections in TX and seems to me that they aren't done for them under a certain length / GVWR. Something I'll need to find out about when I finish freshening up my old 1/2 ton truck-bed trailer. Is there a requirement / cut-off for this in VA?
Post by toynrnd on Feb 18, 2009 6:24:55 GMT -5
Got brakes? Get an inspection. Got two or more axles? Get an inspection.
Post by CORE 4WD on Feb 18, 2009 6:26:47 GMT -5
Thanks for all the tips guys. I'll probably use Thomas, I was next door to them yesterday so I know where they're located at least...
Post by 87B2XLT on Feb 18, 2009 6:38:01 GMT -5
Got brakes? Get an inspection. Got two or more axles? Get an inspection. I think that rules out my trailer, unless I leave the existing drive axle under it (Ford 9"). Plan on replacing that with a regular trailer axle kit or fabbing up something to replace it. Dave G
Post by Deleted on Feb 18, 2009 6:43:25 GMT -5
3000# GVWR = brakes = inspection. Number of axles matters not.
So if you're making a homemade trailer register it with a GVWR of 2999# if you don't want to put brakes on it. Even then I think I'd want brakes on it for safety though.
Post by toynrnd on Feb 18, 2009 7:36:35 GMT -5
3000# GVWR = brakes = inspection. Number of axles matters not. So if you're making a homemade trailer register it with a GVWR of 2999# if you don't want to put brakes on it. Even then I think I'd want brakes on it for safety though. My mistake on the dual axles... FAQs on the State Police website: I have a small trailer and I would like to know if it is required to be inspected. It depends. If the "actual gross weight" is 3,000 pounds or more, it is required to have brakes and is required to be inspected. (The "actual gross weight" is the weight of the trailer plus the weight of any load that the trailer is carrying.) If the "actual gross weight" is less than 3,000 pounds, it is not required to be inspected; however, any trailer under 3,000 that is equipped with brakes is also required to be inspected.
