Post by jlmjeep on May 16, 2010 19:38:17 GMT -5
You can buy a clocking ring off of ebay, they aren't too expensive.
Post by alxj64 on Nov 18, 2010 15:05:03 GMT -5
I can also cut you a clocking ring. I have the template for the 6 bolt pattern already saved.
Post by gtmud on Nov 20, 2010 5:45:39 GMT -5
I had an idea of using the old tail shaft housing from the original auto tranny we had in the YJ. Sort of cut off enough to use the "ring" as a guide, I figure as long as the tranny mount is down and level the holes should line up correctly to drill.
