Samari
Aug 19, 2010 14:32:35 GMT -5
Post by jpeay on Aug 19, 2010 14:32:35 GMT -5
Does any body know anything about suzuki samaris? I just received a free one! ;D It runs good has good 31/10.50 bfgs the tires look like a mud tire but they they say allterrian on the side. Also has a 8k winch on the front. Havent wheeled yet but will try it sat
Samari
Aug 19, 2010 15:27:24 GMT -5
Post by ex-tbd85hilux on Aug 19, 2010 15:27:24 GMT -5
What kind of information are you looking for? Got some specs (ie year?) Pictures?
Samari
Aug 19, 2010 16:12:04 GMT -5
Post by jpeay on Aug 19, 2010 16:12:04 GMT -5
Did the springs mount on top or under the axle? This one they are on top. I dont know alot about them always messed with jeeps. How sturdy is the drive line stuff like that
Samari
Aug 21, 2010 9:49:19 GMT -5
Post by ex-tbd85hilux on Aug 21, 2010 9:49:19 GMT -5
I'm working off memory here from when I was going to build a Sami... The axle's originally were SUA (spring Under Axle) If they are SOA (Over) then it has been modified. The drive line is like any driveline... Depends on how you drive! General rule of thumb with the Sami axles is 33s "can" survive with open axles and some light upgrades but nothing over 31's is recommended if you have lockers.
A easy and somewhat inexpensive up grade is to swap a set of Toyota axles underneath. This has the advantage of a wider track width and larger axle shafts. It also has larger brakes for better stopping with larger tires and there's a lot of upgrades available for those axles. And if you regear the transfer case you shouldn't have to regear the Toy axles. Unlike a standard transfer case the Sami case uses part of the low range gears when on the highway or hi range. This has multiple benefits. Regearing the case gives you lower gears offroad and is generally easier to install in your driveway than axle gears.
This like anything else is based on what your intention's and budget are. There's a lot you can do and some are cheaper then others. Use google and see what you get for hits. There are some things that will need to be done before others and some upgrades that will be needed as things wear.
Samari
Aug 21, 2010 19:11:08 GMT -5
Post by jpeay on Aug 21, 2010 19:11:08 GMT -5
Thanks right now I'm going to concentrait on my cj but will mess with the sami later
Samari
Sept 1, 2010 20:09:27 GMT -5
Post by southernmini3 on Sept 1, 2010 20:09:27 GMT -5
you lookin to sell it or wheel it?
Samari
Sept 1, 2010 20:22:49 GMT -5
Post by jpeay on Sept 1, 2010 20:22:49 GMT -5
I think im going to keep it for now Ive been looking at the tdi conversion. But im going to finish the cj first
Samari
Sept 1, 2010 22:01:22 GMT -5
Post by rroadkilll on Sept 1, 2010 22:01:22 GMT -5
I'll get a guy to sign up that I work with here in ECity and have him tell you about them... he has one and maybe getting another!!!
Samari
Sept 3, 2010 18:58:46 GMT -5
Post by jpeay on Sept 3, 2010 18:58:46 GMT -5
It is for sale details to follow
