Post by bensredyj on Jan 4, 2011 10:35:12 GMT -5
We're dealing with an ongoin factory alarm issue in the zj. Been doing some reading about the problem, apparently the alarm will go off at random when parked, so much so to kill the battery. It seems to be a common problem with the grands. Anyone have this happen to then? How do we fix it? Have heard of the purple wire trick, but being a 97, heard that trick doesn't work. Any ideas?
The owners about ready to sell it if Someone wants it...
Post by toynrnd on Jan 4, 2011 10:50:09 GMT -5
Will she take $100?
Is there a fuse that will disable the alarm?
Post by bensredyj on Jan 4, 2011 10:56:56 GMT -5
Wish there was a fuse but no...
Gona have to do better, needs $$$ for NEXT ride, maybe a Honda in n'orleans area...
Post by bensredyj on Jan 4, 2011 11:25:41 GMT -5
I found this tid bit of info jeeps unlimited
Have a dealer disable the alarm in the Engine computer and the BCM (or replace both with non theft-alarm) AND cut the purple/yellow wire at the BCM before powering up the new units. That's pretty much the only way.
Sound plausible...
Post by JeepCJ5 on Jan 4, 2011 14:06:25 GMT -5
If that doesn't work..... how about finding/disconecting the wire for the horn going to whatever is triggering the horn to go off. If that causes the horn not to work you might be able to rewire the horn. Sorry thats just how I think.
Post by toynrnd on Jan 4, 2011 20:58:27 GMT -5
I found this tid bit of info jeeps unlimited Have a dealer disable the alarm in the Engine computer and the BCM (or replace both with non theft-alarm) AND cut the purple/yellow wire at the BCM before powering up the new units. That's pretty much the only way. Sound plausible... Cut the blue wire....NO, WAIT, THE RED!!! [glow=red,2,300] [/glow]
Post by gtmud on Jan 4, 2011 21:34:13 GMT -5
It sounds like there is a problem with a switch/sensor that monitors access to the vehicle. For what ever reason the vehicle "thinks" that there is an intrusion of sorts. Not sure how the Jeeps are set up, but on a Ford there are event recordings that actually show what triggered the last alarm event. But this is something that your dealer will be able to do only! Guys at Greenbreir or Starr should be able to help you.
Post by bensredyj on Jan 5, 2011 9:49:27 GMT -5
A couple suggestions are to cut the purple wire and ground or to have jeep running an pull the alarm module....
Anyone else.....
Post by toynrnd on Jan 5, 2011 11:24:29 GMT -5
A couple suggestions are to cut the purple wire and ground or to have jeep running an pull the alarm module.... Anyone else..... Master battery cut off switch?
Post by bensredyj on Jan 6, 2011 11:25:53 GMT -5
I believe the alarm will go off when the battery gets reconnected.
Post by KarlVP on Jan 24, 2011 23:30:07 GMT -5
Odd, I have never heard of this, but the wifes jeep (97 ZJ) does do some wonky stuff upon startup.
It acts like the battery is dead and the alternator has to play catch up. The belt squeals for a few minutes, the voltage gauge bottoms out and then after a few miles down the road all is fine.
Post by bensredyj on Jan 25, 2011 9:43:29 GMT -5
That sounds like a whole nothe mess there? Is the alternate workn correctly? Need a new belt? How does your wife open lock her jeep? Key or remote? Were tryn a new battery as step one, maybe a bad red top....
