Post by cooleman on Feb 24, 2011 10:49:51 GMT -5
Does anyone know where I can find a Dan 35 rear axle for a 92 Jeep Wrangler with a 4.11? I am in Chesapeake.
Post by toynrnd on Feb 24, 2011 15:40:52 GMT -5
PNP has 6 XJs on their lot now, you'd have to go look and see what gears they have. Check Craigslist too if you haven't already. There are some YJ axles w/ 4.88s.
Post by cooleman on Feb 24, 2011 16:30:58 GMT -5
Thanks. I called PNP and they said that they didn't have any. I found one on Craigslist but it had the wrong gears. Do you know of any other jeeps axles that might fit?
Thanks again!
Post by A "CJ" on Feb 24, 2011 18:22:27 GMT -5
Post by onzrocks on Feb 24, 2011 20:28:31 GMT -5
I just helped someone get an 8.8 from Pick-n-pull for his YJ, it was ~$230 out the door including the driveshaft. Much stronger than the Dana 35 and you should be able to find one w/ a 4:10. They had a few more down there, but their inventory is always changing.
Post by toynrnd on Feb 24, 2011 21:16:33 GMT -5
PNP didn't have any Wranglers, or the XJs they had didn't have any rear axles?
Post by toynrnd on Feb 25, 2011 20:37:39 GMT -5
Post by ex-tbd85hilux on Feb 26, 2011 9:00:07 GMT -5
Yours is deleted Chris. Here's what you need... And it will only be about $100 more then a rear axle from PNP... Get them, drop a lunchbox in them eventually and wheel them till the tires fall off! norfolk.craigslist.org/pts/2232055901.htmlPaul G.
