Post by Deleted on Mar 8, 2012 10:50:44 GMT -5
I'm pretty sure my valve cover gasket is leaking. Anyone around here have any input on a replacement gasket? Does one brand work better than the other? And no, I won't be using cork. I have no idea if there were differences between the years on the gasket material and valve cover material. Would the valve cover on my 05 4.0 be plastic, aluminum or another metal?
timbillyosu
A bad day fishing is still better than a good day working.
Post by timbillyosu on Mar 8, 2012 11:10:08 GMT -5
Post by Marshall on Mar 8, 2012 11:17:32 GMT -5
K- when I had my TJ I used the basic auto parts store one and had no issues. We did another with high heat rtv and again had no issues...
Post by Deleted on Mar 12, 2012 15:14:55 GMT -5
Bryan did you guys put that RTV on both sides of the gasket, or none at all?
timbillyosu
Post by timbillyosu on Mar 12, 2012 15:24:13 GMT -5
I would put it on both sides and make sure you go all the way around any bolt holes.
Post by brianmlove on Jan 5, 2013 19:46:22 GMT -5
i forget the kind of material i replaced mine with. it might have been cork or aluminum
