Post by PaulC on Jun 28, 2012 19:47:14 GMT -5
This company sells bearing and install kits to fit: Jantz Engineering jantzengineering.com/jantz.php?p=jana-JK Dana 44 gears in a Stock Dana 44 housing. -Reverse Cut Dana 50 gears in a reverse cut Dana 44 housing. -Dana reverse or standard cut 70 gears in a Dana reverse or standard cut 60 housing And if you get carried away -Dana 80 gears in a Dana 70 housing. If you go to their website they show the strength gained by doing the swap. Also refer to post #24 for install info. www.pirate4x4.com/forum/showthread.php?t=883422PaulC
