Post by smrflng on Sept 24, 2012 8:09:47 GMT -5
J,
Hadn't really thought about getting rid of the d-rings yet. But its not a bad idea since the welds don't appear to all that good. Besides they aren't the best of d-rings in the first place.
Russ ;D ;D
Post by smrflng on Sept 26, 2012 9:26:20 GMT -5
Well making some progress, got the old enginge pulled out and the frame mounts and the locating arm bracket have been removed and cleaned up. Russ ;D ;D ;D Attachments:
Post by smrflng on Sept 26, 2012 9:28:21 GMT -5
Here is a picture of the other side. Russ ;D Attachments:
Post by PaulC on Sept 26, 2012 19:47:00 GMT -5
Yeah progress pictures. Keep it going Russ.
Post by PaulC on Nov 7, 2012 17:58:17 GMT -5
Updates?
Post by smrflng on Nov 13, 2012 15:57:09 GMT -5
Not much progress the last couple of weeks, although I have got the oak for the bed stained and a couple of coats of varnish. That has been a fun filled project since I started with rough cut material. It's way cheaper that way. I did finally order the adapter from Luke at 4x4 labs today. So moving forward a little bit a time.
Russ.
Post by smrflng on Nov 25, 2012 17:48:05 GMT -5
Well the adapter should be here on tuesday. Yeah!!!!!!!
Post by smrflng on Nov 29, 2012 11:34:51 GMT -5
Well the adapter has arrived, time to get busy. Russ Attachments:
Post by PaulC on Nov 29, 2012 16:57:14 GMT -5
Ohhhhhhh shiny!!!!!
Post by smrflng on Dec 3, 2012 9:08:47 GMT -5
Well got the engine bolted to the trans and sitting in the truck. Now its time for measurements and the fabrication process to begin. Russ ;D ;D ;D Attachments:
Post by PaulC on Dec 4, 2012 18:30:32 GMT -5
Looks like OEM equipment. Keep up the good work.
necro
Post by necro on Dec 8, 2012 12:14:59 GMT -5
I can't see any of the pictures
Post by smrflng on Dec 9, 2012 17:57:28 GMT -5
A little more progress, got the right side motor mount just about finished. Russ ;D ;D ;D Attachments:
Post by ex-tbd85hilux on Dec 15, 2012 13:49:58 GMT -5
Here's a question I've always wondered about with this kind of swap. How does Virginia view a gas to diesel swap? Is there a way to make it "legal" or since there's no provisions is it already legal?
Post by whoistylerdurden on Dec 15, 2012 14:31:26 GMT -5
If he is running antique plates then it really shouldn't matter. You are right to ask though, you know VA state inpection might find a a problem with it. As far as I am aware of is, orginial equipment for orginial vehicle. Did Toyota come with a Diesel?
