Post by 4WDnRocksNmud on Sept 14, 2012 14:57:21 GMT -5
Looking for a free 5x5.5 wheel with tire that holds air. Doesn't need to be legal, just hold air continuously with minimum/no leakage. Got a trailer in the yard with a tire that doesn't hold air for more than an hour. If u want a rim back, I can give it to you, as a trade.
Post by smrflng on Sept 17, 2012 12:30:12 GMT -5
Cory, how big does the center hole have to be? I've got a ford truck rim with tire that is free for the taking if it will work for you.
Russ ;D ;D
Post by 4WDnRocksNmud on Sept 20, 2012 22:06:20 GMT -5
Russ, it should work if its the same as a cj rim!
Post by smrflng on Sept 21, 2012 12:25:02 GMT -5
Cory,
the center hole is smaller than a cj rim. If you have got an old army trailer it won't work. since the rim has the same size hole as the Grand's with d44 front end.
Russ
Post by 4WDnRocksNmud on Sept 21, 2012 18:52:05 GMT -5
It appears to be a 4" center hole, what I have...
