Post by minibikepilot on Nov 18, 2012 18:24:53 GMT -5
OK..quick question..I am in the process of mating the TH400 to my 304..I was told that the flexplate needed to be weighted.... Now I ordered a flexplate from JC Whitney....it doesn't have any weights on it but they say it goes with my set up...MY question is..will the flexplate have an actual weight welded on the flexplate anyone got a pic or catalog part# that I can reference. I don't want to get this thing together and have to tear it all apart again.. Thanks a lot....
Post by ex-tbd85hilux on Nov 19, 2012 5:30:50 GMT -5
I've never heard of a flex plate being weighted. I have heard of flywheels being weighted though. Typically the flex plate doesn't need weight because the torque converter bolts to it and the fluid mass smooths everything out. I could be wrong though and if I am I'm sure someone here will correct me.
Post by dyds4x4 on Nov 19, 2012 9:14:22 GMT -5
No need for a weighted flexplate. As Paul said....Flywheels, yes. More material=more need for balancing. Fluid dynamics in the Torque converter will negate the need for external weights on the flexplate.
Post by minibikepilot on Nov 19, 2012 17:58:25 GMT -5
keep in mind that this is an automatic th400 with quadratrac transfer case that came out of a mid 70's grand wagoneer. 304 motor... i have purchased 2 flexplates..one has a small piece of metal welded on the front the other does not... just trying to make sure i put in the right flexplate..both were designed for this setup? weird to me...
Post by Deleted on Nov 19, 2012 20:17:30 GMT -5
keep in mind that this is an automatic th400 with quadratrac transfer case that came out of a mid 70's grand wagoneer. 304 motor... i have purchased 2 flexplates..one has a small piece of metal welded on the front the other does not... just trying to make sure i put in the right flexplate..both were designed for this setup? weird to me... Is this how they balance a flexplate?
Post by minibikepilot on Nov 20, 2012 20:24:27 GMT -5
Thats what I'm asking?? to weight or not to weight that is the question
Post by 4WDnRocksNmud on Nov 21, 2012 4:21:07 GMT -5
just weight... the answer will come to you
Post by Deleted on Nov 21, 2012 17:28:17 GMT -5
just weight... the answer will come to you Oh yea, the weighting is the hardest part. I think you will be okay. Mine had small weight welded to it, and was NOS Chevy surplus. I should have bought two. And it is as smooth as a Detroit can be.
