Post by kwayk42 on Apr 10, 2013 15:59:53 GMT -5
This is a 4-Door, 4 wheel drive jeep Cherokee Limited. It has recently had some work done but requires some more to be considered road worthy. Has 146k miles on it. The Wheels are not stock, cost about $400-500 new. Bought in California and brought to Virginia in 2006. Clean Title. The Starter has been tested and is in decent condition. This jeep carries a 140 amp alternator as well. Jeep has been lifted 3 inches (done in California) YOU WILL NOT BE ABLE TO DRIVE THIS CAR IMMEDIATELY What has been done so far: New Fuel Pump New Serpentine Belt New Distributor Cap/Rotor New Spark Plug Wires New Spark Plugs New Water Pump New Battery New Battery Cables New Starter Relay New BOSS Stereo New BOSS Speakers Drained Power Steering Fluid (Required to change water pump) What Needs to be done: Oil Pump Needs to be replaced All Fluids Need to be replaced A/C Needs to be checked New Brakes New Exhaust (Maybe) New Paint (Maybe) New Shocks New Ceiling (Interior - Maybe) What Will come with this jeep (Spare Parts) New Brake Discs New Bushings for the suspension Spare Ignition Coil New Oil Filter Spare Tire Power Steering Fluid Attachments:
