Post by A "CJ" on Feb 21, 2003 10:34:32 GMT -5
shims should stay with the axle at least that is what I have always been told. You will find the axle housing variances are what the shims make up for. I wouldn't just throw the diff in there unless you plan to shim the setup correctly. I have some setup bearings for the dana 30 which make setting up the shims a whole lot easier. Give me a hollar if you want some install help. tim porter in Newport News you know Pat's ghetto....... Not real sure Chris and Craig checked it out last month and couldn't figure it out. It is installed in another front end right now laying in my garage. I am just going to take it out and put my ring gear on it and it should be good to go. They said that as long as i keep the shims and everything the same on each side that it will most likely work just fine. I however have never done this type of work and dont want to end up breaking something i can't fix before i have to use it for work monday morn. It does however look something sorta like a detroit true trac. But, not for sure. Tony
Post by LILREDCJ6 on Feb 21, 2003 13:25:42 GMT -5
I may just do that it all depends on what time i will get done with the derby thing. As long as you have a clue because i dont. I have never ever dug into a dif. I guess that is a lucky thing considering the fact i haven't had the chance to break anything in a dif. I'll let you know. What are you doing Sun? That would be the best day. I may try to take the old front end apart tonight and see how that goes.
Post by A "CJ" on Feb 21, 2003 16:58:51 GMT -5
Sunday sounds fine to me.
Post by LILREDCJ6 on Feb 21, 2003 21:18:48 GMT -5
So what all will we need? Is there a special tool to get the nut off the end of the hub/axle? Are you coming down here? I am not that far from ya i dont think. Just accross the river in suffolk off of 664.
Post by A "CJ" on Feb 22, 2003 9:20:29 GMT -5
parts you may need.
differential bearings
differential cover gasket or gasket material and will make one.
ultra blue RTV sealer
80-90wt gear lube.
tools, big socket for the drive axle nut
do you have air tools and a garage or shop to work in, suppose to be yucky tomorrow.
oh and send me directions to where you are to tjjeep1@cox.net and phone number...
Post by LILREDCJ6 on Feb 22, 2003 16:07:37 GMT -5
Tim i hate to do this but, i need to post pone this for a little while. Something came up and i have to do something tomorrow. I have most of what you said we would need and yes i have a garage with a kerosene heater so you can stay warm. The only thing i dont have is a big socket to fit the hub. May be next weekend if we dont have the cleanup or something else going on. Sorry Tony
Post by toynrnd on Feb 22, 2003 17:45:19 GMT -5
I have big honkin sockets if needed.
Post by A "CJ" on Feb 22, 2003 18:12:41 GMT -5
no problem. tim Tim i hate to do this but, i need to post pone this for a little while. Something came up and i have to do something tomorrow. I have most of what you said we would need and yes i have a garage with a kerosene heater so you can stay warm. The only thing i dont have is a big socket to fit the hub. May be next weekend if we dont have the cleanup or something else going on. Sorry Tony
