Post by MaddRamm on Jan 16, 2003 18:25:52 GMT -5
Hey guys, I just scored another axle for $100. It has the manual hubs and everything, but it is a passenger dropped pumpkin. Will the shafts from the pass. drop one swap out to the long and short side of my driver's drop that I will instal in the XJ?
Post by BIG J on Jan 17, 2003 12:49:24 GMT -5
as i recall all the shafts are different legenths so they are not interchangeable. i think i have a link at home that gives you all the axle shaft measurements i'll see if i can find it
Post by MaddRamm on Jan 20, 2003 18:35:02 GMT -5
If you could send that lin it would be grreeeaaaattt!!! ;D
I found another axle that has the drivers side diff at this same junkyard. So for another $100 I can get it too. Anybody want this other Waggy D44 with passenger drop and manual lockouts?
Post by BIG J on Jan 21, 2003 13:13:48 GMT -5
do you know what year it came out of
Post by MaddRamm on Jan 21, 2003 18:00:59 GMT -5
No earthly clue! I thought there were only four types up front. D44 with the drivers side drop with either manual hubs or automatic hubs. Then the other two axles were passenger drop with either the manual lockouts or automatic hubs. I have seen them with so many different variations it isn't funny! I hear all the time that they only came with such and such on a certain model. So I though if you knew what axle it had, you could tell what t-case and/or which year is was? I know it has a centered AMC 20 in its rear, maybe early 80s....otherwise, no clue.
Post by BIG J on Jan 23, 2003 15:41:08 GMT -5
if it has the drivers side drop then it came with Quadra trac, pass side drop would have the 20 case
