Post by jeeepxj on Sept 22, 2002 20:43:29 GMT -5
Does anyone know the spline count of a Semi-float D60 shafts from a F-250 ?? I'm assuming it has big shafts, but not sure.?.?.?
craig
Post by Lyle on Sept 22, 2002 21:53:34 GMT -5
Hi Craig, Let me start by saying "I don't know", but I did go looking around to see if I could find anything for you. From what I could tell, from places like www.off-road.com/jeep/tech/axle/d60.html it sounds like the semi float would have been 30 splines. The full floater would have been 35 splines. There's lots of stuff out there about the d60, but it gets kinda confusing. Hopefully, someone with experience with them will weigh in with the answer. Whatcha going to do with a semi float?
Post by LILREDCJ6 on Sept 22, 2002 23:25:59 GMT -5
Hey if you are moving up to a 60 in the rear i got dibs on that 9inch because it should bolt right under the yj wouldn't it? Hopefully the price wont be to bad. ;D
Oh yeah you can't have my keys unless you can get them off the wife.
Post by BIG J on Sept 23, 2002 9:21:16 GMT -5
don't get excited, he's not doing anything to the xj, but there is a mystery machine under a car cover in the back yard he's been collecting parts for. a wrangler tub on a full size f250 frame? i smell 44s
Post by toynrnd on Sept 23, 2002 10:54:43 GMT -5
I thought Michelin made some DOT legal 48s???
Post by jeeepxj on Sept 23, 2002 22:03:28 GMT -5
Shoot, what I really want for the Wrangler is a 14Bolt rear, and a Chevy D60 front. I've already ordered some 15x7" rims with a 8 lug bolt pattern. When I get a few more hours OT, I'll order my 27x9.5x15" Baja Belted HP Mickey Thompsons.
Post by toynrnd on Sept 24, 2002 5:47:19 GMT -5
14 bolt AND 27s! Hey big spender, you ought to have almost 3 INCHES of ground clearance. Wait, don't tell me you're swinging the other way...a lowrider YJ??? Say it ain't so!
Post by jeeepxj on Sept 25, 2002 22:17:57 GMT -5
Why are YOU soooo interested in which way I swing ?? Big Boy !!!
Post by MaddRamm on Sept 29, 2002 16:47:37 GMT -5
Hey Craig, why not get a Dana 70? They have one over at U-Wrench-It that is on a huge blue ford 15 pass. van. I already took it off for you! Ain't I a wonderful guy!?! Well, actually I just need other parts but all you have to do is take the shocks off. Also, there are plenty of yard around here with 60, 70 and 14 bolts for cheap. I got my 14 for $100 close by in Yorktown... As far as spline counts, I know that the Full floaters had 30 splines and I beleive the others do as well. For the fun of it, I wouldn't get a semi floater, why not go all the way with a FF?
Post by BroknCJ on Sept 29, 2002 19:30:59 GMT -5
Do the 60 and shave it yourself? Or with a little help from jason?
Post by BIG J on Sept 29, 2002 21:43:25 GMT -5
oh oh let me try; i bet i could shave it really quick with the torch! BTW my sources say that the only 35spline 60s came in the HD 60s that are found under ambulances and such
Post by jeeepxj on Oct 2, 2002 22:14:29 GMT -5
I remember reading that somewhere as well.. Look who's also having an identity crisis ?? And what's up with the "modified" 4 door ?? MODIFIED ?? Maybe a lil bent up, but not modified.!.!.!.!
