Post by MaddRamm on Feb 21, 2003 19:00:09 GMT -5
Post by MaddRamm on Feb 21, 2003 19:02:59 GMT -5
Do you need these no matter what hub you are using? Cuz I need the 6 lug stuff and was planning on running the hubs I already have, just putting the flattops in there. I know the caliper mounts different, but other than that, *I* don't need these correct?!
Post by BIG J on Feb 23, 2003 17:40:04 GMT -5
those are the spindles that I need. the ones you need use a larger inner bearing like the ones that you pulled off that Ram. the ones you will use are much more common too, all the waggys at UWI have those.
Post by MaddRamm on Feb 24, 2003 12:01:27 GMT -5
Ok, so I am ok...good. I will keep an eye out for any spindles like you need and let you know. But then again, I think you got to UWI all most as much as I do! I keep seeing your XJ, but never can find you....
Post by BIG J on Feb 25, 2003 12:32:20 GMT -5
did you check in the import section? always some interesting stuff over there, and LOTS OF VOLVO PARTS!
Post by MaddRamm on Feb 25, 2003 19:46:10 GMT -5
Yeah, I used to go over there and get Volvo stuff....mostly just the compressors since they are the sweet York 210s! But since I have a few of them, I really don't go over there much anymore except to help somebody get toyota pieces....Is there something more to Volvos that we should know? Do tell!
