Post by q on May 30, 2003 20:16:51 GMT -5
Ok I have a 1984 CJ7 with a 4" lift, 258, "Juice Box" ignition upgrade and a Webber 32/36 carb.
Last night I got a little squirley and did the "Nutter Bypass" and then ripped out the computer and all of the unnecessary (I hope ;D) wiring. Now I have the computer out of the timing process and I need to adjust the timing but I am not sure I have all of the vacuum lines correct.
So my question is...Has any one in the area done this or are there any carb experts out there that could take a look at this POS?
Oh and while I am asking for help I will be doing a YJ tub swap in June, anybody have any advice on that too?
Thanks, Mike
Post by Deleted on May 31, 2003 7:51:04 GMT -5
Hey Mike, I don't know about your ignition problem, but the CJ frame will only need one body mount moved. I did swap the 258 for a 304. I used the stock 258 ignition with a later 360 distributor.
Post by GreatCJ8 on Jun 1, 2003 21:15:53 GMT -5
Hi, I have a CJ vac diagram on my site, www.greatcj8.comJust click on "Tech Diagrams" on the left side, hope this helps ...another Mike
