Post by LILREDCJ6 on May 18, 2003 14:26:47 GMT -5
Hey Big J can you make me a couple of these mounts? www.bc4x4.com/pv/yj/ss/ss15.jpg I hope this link works for ya. I am not to sure how to link things but, i hope it works. They look real easy and shouldn't catch on anything anymore either. I am probably getting a set of u-bolt flip kits for this thing. If we can do this then it will be pretty much clear under the axles. Tony
Post by MaddRamm on May 20, 2003 18:30:48 GMT -5
Those look like regular shock mounts just clocked 90*. I have some differen't shock mounts I have cut off of various axles if you wanted them. Or, yours could be cut off and turned to weld.
would the angle iron trick that Jason used for my axle work? You could just turn the shock right?
Post by LILREDCJ6 on May 20, 2003 22:24:32 GMT -5
We figured it out and it should be pretty trick once it is done. He told me no on the type you guys have because it will bind the shock. I only have 1 mount left the other one broke in half sometime after the fast downhill backward run and rausch creek the next day.
Post by BIG J on May 21, 2003 17:57:12 GMT -5
ya'll need to stop advertising that i know how to turn a wrench
Post by bensredyj on May 22, 2003 9:01:11 GMT -5
HEY Tony, it looks like what I ordered from 4wd, the Tera rear lower shock mounts, they are jsut some 1/8 steel bent into a U or so box and has a hole drilled for the shock mount, I was gona go this way till my welder said you shouldn;t weld a flat edge to the round axle tube due to stress issues and the colapse lenght of the shock may have issues. SO instead had the stock mounts welded back on after the driver side broke off TOO. SO I have the mounts $12 plus shipping. BEN
Post by LILREDCJ6 on May 22, 2003 22:34:56 GMT -5
Thanks but, my dad has some made and i will be getting them this weekend. Post them babies though you know someone will buy them. Mine broke in half. It will be pretty trick once we get them on. I know i can't wait it rides like heck with only 1 back shock. Tony
