Post by GreatCJ8 on May 20, 2003 7:50:23 GMT -5
Hi, I need to get the ring & pinion set on my Jeep. I have the carrier, new install kit, new seals, bearings, U joints, etc. The guy that did the rear axle cannot do the front for me. Where is a good place to get this done around Chesapeake, the axle is off the Jeep...
Post by N2Rocks on May 20, 2003 15:28:24 GMT -5
Standard Parts Corporation in Chesapeake does gears. I'm not sure what their cost is for gears.
Don
Post by GreatCJ8 on May 20, 2003 18:31:07 GMT -5
Thanks! I'll give them a call tomorrow. BTW, I already have the new ring & pinion too, I forgot to add that above. oh & in case anyone searches the board for this type of info in the future: Standard Parts Corp 956 Providence Rd, Chesapeake, VA 23325 Phone: (757) 424-4450
Post by MaddRamm on May 20, 2003 18:32:57 GMT -5
Hey, let us know how much they charge. I am gettiing to the piont where I just don't have the time or energy to instal mine....might be worth it t pay someone.
Post by GreatCJ8 on May 21, 2003 8:14:52 GMT -5
Well, I called & they normally do this type of work but they currently don't have a mechanic that can do this... this is the story of my whole rebuild.... My axle has been off for far too long, can anyone suggest a good shop that can change out the wheel bearings, U joints, steering knuckles so I can at least drive around in 2wd (it's been in my garage for waaay too long, I'll get the front R&P set later.. or if someone can do this at my place I'll pay you..
Post by toynrnd on May 21, 2003 11:08:06 GMT -5
Check w/ Pro Trucks, they should have a mechanic to do all that plus your R&P.
Post by GreatCJ8 on May 21, 2003 16:10:57 GMT -5
oooh boy, $350 just for R&P
I only spent $200 to get the rear done & that included installing the locker too, but he can't do the front for me...
Post by A "CJ" on May 21, 2003 17:08:59 GMT -5
How soon do you want it done? Might be able to help you out......
