Post by MaddRamm on Jun 30, 2003 13:35:28 GMT -5
Hey guys,
I would appreciate some input on my XJ D44 project. I have a few questions but will give you the story first...
My Waggy D44 rear axle supposedly never came with a crush sleeve. I talked to Gregory's a couple of months back seeing if I could get the shims, bearings, crush sleeve for installing gears into this D44. They said that when they ran the BOM that it didn't call for a crush sleeve.
Well, I have run the BOM myself at Dana's site www2.dana.com/expert/wc.dll?DSD~deabill~2 and in fact, many other boms....most often the pictures and kits have no mention of a crush sleeve in any of the kits! FYI, if you want to run it, the BOM for this axle is 605285-2
I have many Dana axle parts manuals/catalogs for Fords and other vehicles...the picutres almost never seem to show the crush sleeve for front or rear axles and it doesn't appear in most parts kits.
To further this mystery, I finally took apart the axle yesterday and removed the 2.73 gears. Low and behold...there was NO crush sleeve between inner and outer pinion bearings.
Here come the questions.....How was the preload ever set on the gears when it came from the factory without a crush sleeve? Don't all axles come with crush sleeves? Or are crush sleeves something not necessary in the actual assembly process but are used when gears are swapped???
Now, do I need to worry about a crush sleeve or can I just get the Dana/Spicer parts kit from Gregory's Fleet Supply without the crush sleeve? If so, how would I set the preload and not squish the bearings too much? Jut be silly careful on tightening the nut???
Also, I was going to instal the 3.54s I have (both from Dodge D44 front ends...I kow, they already have a lsight pattern being run the other way....) and those gears had the crush sleeve on them. Obviously I don't reuse it....but if my housing doesn't call for a crush sleeve, would these gears be all right without one?
I know this is a bunch of stuff, but I appreciate you input...trying to get this axle under there! Once I get the gears installed I will be able to just slap it under there.
