Post by lifted79cj7 on Feb 16, 2003 1:29:26 GMT -5
www.crosslander4x4.com/toc/Kinda different, but would make a good trail rig. Wonder what all the drivetrain has??? Looks like a Wagoneer and a Range Rover had sex and porduced this thing. Jack
Post by frog975 on Feb 16, 2003 17:45:11 GMT -5
Huh, looks more like a Samari and an old Bronco... ;D
Post by lifted79cj7 on Feb 17, 2003 2:09:43 GMT -5
Well they sell them here in Norfolk it says, so who's gonna go test drive one?? ;D Jack
Post by jpnut on Feb 20, 2003 10:31:53 GMT -5
Maybe it should be the next club outing, everyone show up in your 4X and test drive it.
EricT
Short Timer!
Post by EricT on Feb 20, 2003 11:32:19 GMT -5
CROSSLANDER 4x4 SPECIFICATIONS Engine Aspiration Inter-cooled Turbo Diesel Displacement (cm3) 2785 No. of Cylinders 4 Bore & Stroke (mm) 93/102.5 Compression Ratio 19.5:1 Maximum Horsepower 132 R.P.M. at Maximum Power 3800 Maximum Torque (Nm) 355 Transmission Wheel Drive Permanent 2x4 rear/part time 4x4 Gear Box Make Eaton Type FSO-2405-D No. of Gears 5 + 1 Synchronized Ratio of Gears 4.473; 2.458; 1.472; 1.000; 0.809; reverse 3.795 Transfer Box Make Cross Lander Clutch Hydraulic control Suspension Front Axle Coil springs & shock absorbers Rear Axle Leaf springs & shock absorbers Differential Symmetrical Ratio 3.18 Brakes: Hydraulic Dual circuit, power assisted Front Ventilated Disc Rear Drum Power Steering Hydraulic Power Assisted Wheels: Rims 7JJX15CH Tires 235/75 R15 Electrical System Alternator 850 Watts / 85 Amp. Battery 12V, 2x66 Ah Performance Maximum Speed 90 MPH Turning radius 36 feet Maximum Slope 40 degrees Fuel Consumption 23.4 MPG @65 MPH Towing Capacity Trailer with Brake 5,799 lbs. Trailer without Brake 1,653 lbs. Dimensions Length 166.3 Inches Width 72.2 Inches Height 72.9 Inches Wheel Base 92.5 Inches Ground Clearance 7.8 Inches
Warranty Cross Lander Vehicle Warranty
Cross Lander U.S.A. provides a New Vehicle Bumper to Bumper limited Warranty to every new owner. The vehicle is warranted for repairs, including parts and labor to correct problems in material or workmanship for 3 years or 36,000 miles.
Crosslander Accessory Warranty
All Cross Lander accessories have been designed and developed specifically for your new vehicle. The Cross Lander accessories are backed with the same 3 year/36,000 mile New Vehicle Bumper to Bumper Warranty when installed at the factory.*
Replacement Parts Warranty
Replacement parts installed by a Cross Lander dealer are covered for 1 year or 12,000 miles, whichever comes first.
*Note that those Cross Lander accessories installed after delivery will carry a 1 year 12,000 mile warranty.
INFORMATION SUBJECT TO CHANGE WITHOUT NOTICE COPYRIGHT CROSSLANDER U.S.A. 2002
ALL MATERIALS COPYRIGHT CROSS LANDER U.S.A. 2002
Post by ScramblerPat on Feb 20, 2003 13:35:21 GMT -5
I did not see any parent affilation, I would say landrover wanna be
Post by toynrnd on Feb 20, 2003 16:56:21 GMT -5
This looks very much like an ARO. They brought one when we wheeled on the Rubicon Trail. It was running at the end of the trail, but I have photos and video of the damage...OUCH!
