Post by CORE 4WD on Jun 4, 2008 21:19:30 GMT -5
Got some more done- Passenger side wheelwell housing is almost completely welded in- Housing prepped. The housings needed to have one part of the inner flange cut off about 3/4" higher than what it came with. It's got a nice curve which fit the plasma torch great to guide it around. Zip disc would work great too or air shears. Drilled 1/8" holes for spot welds- Clamped in, clamped next to each spot weld also, to ensure pieces were tight to each other- Miller 180 Auto-set worked great. Extensions are a good bit thinner than factory sheetmetal but no burn-throughs yet (knock on wood)- Mostly welded in-
Post by CORE 4WD on Jun 7, 2008 17:20:25 GMT -5
Just need to OSPHO and paint wheelwell extensions, now on to engine install...
Post by CORE 4WD on Jun 24, 2008 5:33:05 GMT -5
Here's some poser shots now that I have rear fenderwell clearance- Thanks Billy for the use of your ramp!
Post by Deleted on Jun 24, 2008 9:18:17 GMT -5
Looking good! You just had to take it out after wheeling Billy's over the weekend didn't you? Can't wait to see it on the rocks.
Post by CORE 4WD on Jun 25, 2008 19:30:30 GMT -5
Got that right Keith! Engine swap will commence July7 as per the Boss...
Dave
Post by 87B2XLT on Jun 28, 2008 21:07:18 GMT -5
Looking great, Dave! I'm sure you're happy with how things have finally come around on that thing. I just wish I could be there to see it up close and personal on it's maiden voyage Dave G
Post by CORE 4WD on Jul 17, 2008 21:09:26 GMT -5
Got some more stuff done- Pulled fenders off, I'll be painting them before putting them back on- Engine ready to come out, PaulC you don't really want those "Powered By Ford" valve covers do you? ;D New 351W engine, JET Performance Quadrajet (B.C. Broncos)-
Post by jeeepxj on Jul 19, 2008 11:15:19 GMT -5
Let me know if you need a hand @ finding a deal on a truck and trailer for that beast..
Post by CORE 4WD on Jul 19, 2008 21:49:46 GMT -5
I do, actually...I've got cash in hand but it isn't quite enough to snag Adam's truck. Whatcha thinkin'? I've been all over EBAY and Craigslist.....
Post by CORE 4WD on Jul 29, 2008 16:14:23 GMT -5
Thanx Jim and Bill for the muscle- It's hot and I'm happy to be rid of the old engine, although I never could blow it up. Come and get it Paul!-
Post by Jim63 on Jul 29, 2008 17:04:51 GMT -5
no prob that was fun! Now we just need to get the new one in!!
Post by CORE 4WD on Aug 2, 2008 18:31:24 GMT -5
Engine compartment is degreased/pressure washed. Gregory's resurfaced my flywheel and hooked me up with a performance ceramic clutch on the cheap. Just need to grind off old ghetto-fab mounts and weld on new ones, paint engine compartment....
Post by broncobilly on Aug 2, 2008 20:20:16 GMT -5
When u get back from travel I'll be glad to give u a hand putting in new engine.
Post by CORE 4WD on Aug 19, 2008 20:43:13 GMT -5
Gurls went to Jonas concert, I went into garage. Got the passenger side old boogered up misplaced engine frame mount cut off and frame rail cleaned up. Driver side is cut off, needs ground down and cleaned up on frame rail....
Post by CORE 4WD on Sept 16, 2008 5:57:00 GMT -5
New motor mounts are welded into frame. Engine compartment is painted. Pulled new engine out of stand and installed engine mounts, pilot bearing, bolted on flywheel, harmonic balancer and clutch pack. Probably stick it in the bronco sometime today... I really can't wait to re-wire the bronco and get all the crusty wiring out of it!
