Post by PaulC on Mar 27, 2006 21:50:20 GMT -5
For sure beef the frame to the other side, or build a steering box brace to attach to the other frame rail. Track bar wouldn't be to bad to make either. Might need it with that amount of lift you have. How did the weekend go.
Also if you want to come up and grab the pitman arm link it is sitting by the garage door on the floor inside. Ask Jenn to open up the garage.
Post by sinwagon on Mar 28, 2006 19:14:56 GMT -5
yeah it needs the track bar i had josh move the steering wheel for me so i could watch what was going on. the springs shifted a lot when steering
Post by sinwagon on Jun 20, 2006 14:11:55 GMT -5
i started on a new front bumper/winch mount this weekend that will also add in the frame stiffener. i am going to recess the winch into the front of the truck so i have better approach angle. with the 1/4" plate going from frame rail to frame rail and some added supports then it should be good to go. when removing the front frame crossmember i found 3 of the 4 rivits that tie the frame to the support and spring perch were loose, so that added to the frame movement at the steering box. will have pics to post this weekend, night shift is killing me on getting anything posted.
Post by Chele on Jun 24, 2006 15:56:16 GMT -5
I meant to ask you today- was that a BRAND NEW tow vehicle?! I don't seem to remember u having that before and if so....is the old tow vehicle gonna be for wheelin'?
Post by sinwagon on Jun 25, 2006 10:24:43 GMT -5
yep new tow vehicle and the old one is up for sale so if anyone wants a new wheelin vehicle or if your loking for an exelent V8 swap then it is a good one for it.
Post by sinwagon on Jul 16, 2006 20:17:43 GMT -5
well before the work weekend at Harolds i found out that i had broken a mount on the steering box at crozet. i started the changes by taking off the old bumper. here is how far the old bumper stuck out. bumper removed. i originally thought about mounting the winch from the bottom like this. changed my mind about that because of remote connector and freespool clutch lever locations, so i decided to "french" it into the grill for better approach angle. so after replacing the steering box today i built a brace for the frame. and a pic of the end of the brace at the steering brace.
Post by sinwagon on Jul 16, 2006 21:22:26 GMT -5
just thought i would throw this one in the is what the truck looked like before the pre run at oakridge last year.
Post by Chele on Jul 17, 2006 4:37:28 GMT -5
Good grief...it looks like it's shiny. Unbelievable!!!
